USB programming cable
I have a laptop without a serial port and have to use a USB - Serial
adapter which is a pain in the neck to use and carry around. Is
there anyway of using USB straight?
Al
Al
and other boards, driving the cost up substantially. The makers of those
adapters have a much bigger customer base than us and can keep costs down
lower than we'd be able to.
-- Jon Williams
-- Parallax
In a message dated 11/10/02 9:37:23 PM Central Standard Time,
brownstamp@y... writes:
Is there a USB interface chip someone could make an interface board out of?
This sounds like a good project.
> Not at this time. We would be forced to put USB adapter circuitry on our
BOE
As used in my adapter. It is a USB to RS232 chip (at TTL levels).
> From: Rodent <daweasel@s...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sun, 10 Nov 2002 22:00:06 -0600
> Subject: Re: [noparse][[/noparse]basicstamps] USB programming cable
> Jon,
> BOE
> of the message will be ignored.
would probably turn up quite a bit of good information.
-- Jon
In a message dated 11/10/02 10:00:27 PM Central Standard Time,
daweasel@s... writes:
> Jon,
that could replace the normal serial cable. Like Jon said, wether it works
with the stamp ...?
Perhaps someone has used it and can inform us.
Regards peter
Oorspronkelijk bericht
Van: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=H0N_Y_0VVySUKvXEO2Ms9yjilgLQo7eh-kz47_KcVb2KDbw4OWBdIZLoMDW3tjRaOeiiHuYog0-v2XcjsnU]daweasel@s...[/url
Verzonden: zondag 10 november 2002 20:00
Aan: basicstamps@yahoogroups.com
Onderwerp: Re: [noparse][[/noparse]basicstamps] USB programming cable
Jon,
BOE
number you specified may or may not be the same unit. There was a posting
here several weeks ago from someone who had made their own adapter using a
USB part from DonTronics. Search past postings and you should find it. The
person that developed this did a great job on this project and was very
thorough!
> thorough!
http://www.lennard.net.nz/electronics/usbtors232.html
> From: azeasi@a...
> Date: Mon, 11 Nov 2002 13:31:05 EST
> The Targus Port Replicator does NOT work with the Stamp! But The Targus part
> thorough!
