does the new windows editor adjust for the stam p in use?
I'm just guessing but the pause is a fixed loop for 1 milli in the basic
code for that chip. The others require you to understand the clock speed
because as is often stated on this site the pbasic interpreter has only a
few bits left ( not enough space to add conditional statement.
From: Mike Walsh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-dSjUZaEC1h4nCAcb3M1B0uwrh4oCM1TFaz7AjoTOIU0tayL_mLPbZgw3dKFJDxjzX4w2_Yb4SaU]walsh@c...[/url
Sent: Friday, November 08, 2002 10:22 AM
Subject: Re: [noparse][[/noparse]basicstamps] does the new windows editor adjust for the
stamp in use?
Jon,
Why is that? If pause command can compensate for processor speed, why have
other clock dependant commands not behave the same way? It seems strange
that you should have to look up baud rate parameters on a table for
different Stamp models.
At 08:45 AM 11/8/2002 -0500, you wrote:
>No. The PAUSE parameter is always specified in milliseconds, but other
>commands require adjustments to the parameters for each processor. Consult
>the help file or manual for specifics.
>-- Jon Williams
_________________________________
Mike Walsh
walsh@i...
stamp in use?
Jon,
>-- Jon Williams
Mike Walsh
walsh@i...
with the interpreter in the BASIC Stamp. IF-THEN-ELSE (and other niceties)
in the editor will be available soon.
-- Jon Williams
-- Parallax
In a message dated 11/8/02 9:31:03 AM Central Standard Time,
porter.sadler@s... writes:
