Store Command?
I am looking into the Store Command but its usage isn't clear to
me. The BS2p has accessible EEPROM from 0 - 2047 when using
Read/Write, but when using Store it can make the available memory be
14 kbytes. I am just wondering if in each program slot specified by
Store are there 2048 spaces of accesible memory and will the memory
of each program slot be preserved, or does the data in one program
slot get overwritten by the data in another program slot
Thank You
Thank You
other than the one that is currently being RUN.
RUN 1
' in bank 1
x var by;te
read 0,x ' reads from location zero in bank 1
store 7
write 0,x ' stores that same value in bank 7
Programs work down in eeprom from the highest address in the bank
(2047), whereas DATA usually starts from 0 and works up. Usually
there is no conflict, unless you reach a point where the two collide
in the middle. Some banks you can allocate for data only.
If you want to be tricky, you can on purpose READ program tokens from
one bank or from some other source (a modem say), and WRITE them into
another bank, and then RUN that bank.
-- Tracy
> Thank You
