Hi
Hello everybody,
I'm a student from Los Altos High School and I'm completely new to
the BASIC Stamps. We are building electric and solar cars that
compete in Electrathon and Solar BikeRayce events. I am looking for
information on how to build a DC voltmeter (0mv ~ 200V) and display
the voltage on a LCD screen. I understand that I need a BASIC Stamp
module, board, A/D converter, and a LCD screen. Can anyone give me
some advise on what should I buy and how do I build this voltmeter?
Thanks for your help!
Kurt Liu
Kurt Liu
using the Stamp for is as a volt meter.
> From: "kurtliu85" <kurtliu85@e...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Thu, 07 Nov 2002 01:35:57 -0000
> Subject: [noparse][[/noparse]basicstamps] Hi
> Hello everybody,
> Kurt Liu
> of the message will be ignored.
Thanks for replying to my message. Actually, I intended to use the
BASIC Stamps to measure the milivolt drop across a 50mv:50A shunt to
approximate the amperage flow in our electrical system. Then, I
wanted to use the BASIC Stamps to calculate AmpHr and display it on a
LCD screen. Can you give me any information on what I need to buy?
Sincerely,
Kurt
--- In basicstamps@y..., Ben <ben@l...> wrote:
> It might be easier to use an Intersil 7106 in this case, if all you
are
> > Reply-To: basicstamps@y...
> > Hello everybody,
for
display
Stamp
voltmeter?
> > Kurt Liu
> > basicstamps-unsubscribe@y...
Subject and Body
I just thought originally that you wanted a simple volt meter. :-)
Any one else got any ideas??
--- In basicstamps@y..., "kurtliu85" <kurtliu85@e...> wrote:
> Hey Ben,
> Sincerely,
> Kurt
> are
> > > Hello everybody,
> for
> display
> Stamp
> voltmeter?
> > > Kurt Liu
> Subject and Body
| Um, er, Power electronics isn't my area... :-\
Yes...
Copy of a message I sent a few weeks ago...
On the other hand, if you want to make another measurement (like amp
hour), with the same Stamp and the same alphanumeric 16-character
LCD,
then I would use a Stamp and a 2-chanel A/D converter (MAX 110 or MAX
111).
Now to measure amp hour, you need a clock, yes ? Then have a look at
Dallas Semiconductors DS 1302 (on Maxim's site). It's a great
real-time clock with a battery or supercap backup system.
Those 2 circuits (MAX 110 and DS 1302) saves Stamp pins (4 and 3-wire
communication). You need some more Stamp I/Os for the LCD...
This is only an idea on how I would begin.
Have a look at www.maxim-ic.com, you'll find the complete datasheets.
Hope this helps...
Phil.
msrajums@h... writes:
I am new to hardware programming and I have exp in software programming in
C++/C#(dotnet).
I need info about these.
1. I would like to know which is the best way to learn about
microcontrollers. Which kit is the best for experimenting the things...
2. Suppose I write some module in c++ and C sharp, how do I put that into
information in chip.
3. Suggest some urls/books.
Thanks in advance
MS Raju
I think the first question is what do you intend to do with your uControllers?
HANDS DOWN the basic stamp is the is the best way to learn about
microcontrollers. Parallax (www.parallax.com) has excellent tutorials that
make the stamp usable by ANYBODY who can read and connect wires to a breadboard.
The basic stamp and the documentation you get from Parallax, code examples,
hardware examples.......there is no better on the planet!!!!!!!!!!!
The code is very easy (Pbasic). The only drawback is the speed of the
controller, and $$. Generally speed is not a problem though, as many people who
contribute to this forum have built some remarkable devices with the basic
stamp.
Cost is $50 for the BS2, support is unlimited and excellent.
For pure speed....20 ns / clock cycle, and 1 to 4 cycles to execute an
instruction the SX by Ubicom (and also sold through Parallax) is an excellent
uController, but not for the weak at heart programmers.....assembly language,
but
this should not be a problem for you. Less than $10 for the IC and Resonator,
and there are not nearly as many posts in the Yahoo forum for this device (SX),
but I have never failed to recieve support from the forum. Also a one time
~$180 programmer which has a nice debug feature, you can single step through
your program.
So it boils down to what you want to do with the uController, and balance
ease of programming vs cost and speed of execution.
Try looking at www.sxlist.com for info on the SX.
microcontrollers is probably the Basic Stamp 2,
24-pin version. It is simple, it gets you
used to the simple way you have to do things
in microprocessors, and it takes care of a
lot of tiny details for you.
Tiny details like: clock chips and routing
clock signals. Providing reliable power.
Providing an operating system. Providing
a debug system.
Once you've used the BS2, then you can
'graduate' into 'real' PIC processors with
the CCI 'C' compiler.
Note by 'simple', I mean in C++ you have
LOTS of libraries you can use that give
you complicated functionality. In the
microprocessor world you are a lot closer
to the hardware.
See www.parallax.com, in their Nuts and Volts section.
See www.phanderson.com
See www.rentron.com -- look in their PIC section
--- In basicstamps@yahoogroups.com, "M S Raju" <msrajums@h...> wrote:
> Hi,
programming in
> C++/C#(dotnet).
things...
that into
> Thanks in advance
> MS Raju
C++/C#(dotnet).
Thanks in advance
MS Raju
further.
Here are the more details which you asked.
My ultimate goal is to build (digital video recorder) for. I have some time
to complete this and I can do some learning in that direction meanwhile. So
I guess I have to concentrate on CMOS camera and LCD related stuff.
I have pretty good experience in image related stuff in c++ and c#.
I have checked the parallax website and there are thousands of different
kind of boards..I am confused, which one to buy.
Also I am not familiar with basic language. So Is there any alternative for
using c++ or c or csharp. If yes, which C++ KIT IS best for my requirement?
Thanks for any inputs and your time.
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hAr91dYbZVSHCDi2wIJCwSe4qIbkX64ClKiv8oXUnI4_r5rN-DdRyrO2T-iKEnWU4sw5V8r_nMU]smartdim@a...[/url
Sent: Friday, October 10, 2003 1:47 PM
In a message dated 10/9/2003 9:10:58 PM Pacific Daylight Time,
C++/C#(dotnet).
Thanks in advance
MS Raju
uControllers?
breadboard.
who
stamp.
excellent
language, but
Resonator,
(SX),
your program.
I checked the parallax website and there are many controllers.
Can you suggest me which one to buy. I am c++ programmer so its will be
better if I have c lang or c++ based controllers.
My ultimate goal is to build the DVR(digital video recorder).
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VZcRwC3jpPAUKfslssta2J_RZyquzQ9X5AwFbO0gMfuGOgCFU06DUFJXN18bAITsn0Edygm7wShwmBqttG6LGOTE]allan.lane@h...[/url
Sent: Friday, October 10, 2003 10:48 PM
I think the best platform to learn about
a debug system.
to the hardware.
> Hi,
programming in
> C++/C#(dotnet).
things...
that into
> Thanks in advance
> MS Raju
language is an embedded version of BASIC; you cannot program it in C,
C++, or C#. We also have a controller called the Javelin Stamp that
programs in a subset of Java, perhaps that's a better fit for your
desires to learn about microcontrollers. You can get a starter kit that
comes with everything you need to get started. Here's the link:
http://www.parallax.com/detail.asp?product_id=27237
Again, the Javelin programs in Java -- not C, C++, or C#, but it
shouldn't be any real struggle for you as Java is so similar to C.
Ultimately, any micro that runs an embedded virtual machine (like the
BASIC Stamp or Javelin Stamp) may not run fast enough for your
application. At that point you can switch to a stock micro (like the SX
or PIC) and program it with a C/C++ compiler. The SX and many PIC
micros are flash-based so you can reprogram them easily. We carry
materials for the SX micro and there are third-party compilers available
for it.
-- Jon Williams
-- Dallas Office
From: M S Raju [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QX0ANwoLrVo9r9fO516Fnuzmn3vklPkEaX9Z0kRhiEQI19AuW2n72Z1MRzYwiS-3hDigCYKuUu0SKsyYuU6b]msrajums@h...[/url
Sent: Sunday, October 12, 2003 6:37 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Hi
Thanks for the information.
I checked the parallax website and there are many controllers. Can you
suggest me which one to buy. I am c++ programmer so its will be better
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=b6Vv4RKiMpfNiV5ZSuS5kGNuIWc_hRjY62HEAHqe2d5C8rJ7TtgG-n4movSQVdvxcYx3lOsUORFP-efJnfuvIm90vQ]allan.lane@h...[/url
a debug system.
to the hardware.
> Hi,
programming in
> C++/C#(dotnet).
things...
that into
> Thanks in advance
> MS Raju
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
to C++. Other then that there is no stamp that is programmable in C++. The
SX can however be programmed in C. The catch is you have to buy a C
compiler for it and from my understanding they aren't terribly cheap. Also
consider the fact that with the SX the unit cost will be lower but the
initial cost is significantly higher as you need the compiler and
specialized programming hardware i.e. SX-Key. I totally agree with everyone
on that the basic stamp 2 is the best for learning microcontrollers. PBasic
is a walk in the park to learn so don't let the fact that it's a language
you don't know scare you off.
Well that's my two cents.
Chris Shuster
Sent: Sunday, October 12, 2003 5:36 AM
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0E_BIOQ0Knv8f_cj57axZhSwkPtS8zPP9LvNxfk44-kHwL49ew4cDA_22AGtGbGNckwF3lOm7J-WGZh9GSK0PyOYyYFv]allan.lane@h...[/url
> a debug system.
> to the hardware.
> > Hi,
> programming in
> > C++/C#(dotnet).
> things...
> that into
> > Thanks in advance
> > MS Raju
I've written extensively in C/C++, and coded enough java to understand
that at its fundamental, they are totally different. Structurally, C is an
iterative programming language and Java is more like smalltalk in that it
deals with object messaging and threads.
> for it.
> -- Jon Williams
> -- Dallas Office
> From: M S Raju [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OlOnKgpePnXSmrXFhv7R8BkXx2CMo5NvPI83VKAQi1gOB1ujVCwdHdqL2uNUHVAxi4no2V5uVYxQEFqFJxKY]msrajums@h...[/url
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Vus1diS_WhX13CUR6Vtli9HHdSviirUc-xNF77Y8kYLnwNCYCCjPhP1ffyrM3DIMoWqcgG1Y0H8ha-scIGnktqi3QJQ]allan.lane@h...[/url
> a debug system.
> to the hardware.
> > Hi,
> programming in
> > C++/C#(dotnet).
> things...
> that into
> > Thanks in advance
> > MS Raju
> abuse@p....
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
lamont@a... writes:
What kind of java implementation does parallax have that makes this true?
_______________________________________
If you can write in C and C++, you MOST CERTAINLY can write in PBasic. The
documentation is superb, help from this forum superb. Again PBasic is EASY. I
learned it on my own with no programming experience, certainly a C / C++
programmer can pick it up literally in less than one hour.
Ken
there.
http://groups.yahoo.com/group/javelinstamp/
In a nutshell, the Java implementation on the Javelin is a
single-threaded subset. That said, the speed of the SX allows us to
install background peripheral objects; things like UARTS, PWM, and
timers.
-- Jon Williams
-- Dallas Office
From: Sean T. Lamont .lost. [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=uLCaryHIOUR6spxznra_Q0Q-cptKN4wxDl_53n6AXdKrPJSW5dyc58Arf3Du5P4fl5kS7RxynmcSW-bCoQ]lamont@a...[/url
Sent: Monday, October 13, 2003 2:38 PM
true? I've written extensively in C/C++, and coded enough java to
understand that at its fundamental, they are totally different.
Structurally, C is an iterative programming language and Java is more
like smalltalk in that it deals with object messaging and threads.
> SX or PIC) and program it with a C/C++ compiler. The SX and many PIC
> available for it.
> -- Jon Williams
> -- Dallas Office
> From: M S Raju [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8kMQI5VAiZyQ-7j-VgLZMcU4wJ6chxiCiVwAs49ArQu3GP6_RV1D-5iS0RjvwXbBquIY2H7j_jF7Vd1jkBE]msrajums@h...[/url
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pPSn2sG9a8CWZlLjdAVLebJkinfMAu0h34krMrW1cUAB2WHtrwk1e682J56Ge1a1DfD5yh9caaZ4SWdTMNEkztHpgp4]allan.lane@h...[/url
> a debug system.
> to the hardware.
> > Hi,
> programming in
> > C++/C#(dotnet).
> things...
> that into
> > Thanks in advance
> > MS Raju
> abuse@p....
Bremerton
abuse@p....
to how PBasic compiles to Basic 'PCodes'.
Parallax has a Java bytecode interpreter in a chip.
Their 'Javelin' processor has a 32K eeprom where
your bytecodes and their interpreter reside. When
you start the chip, all is copied to a 32K SRAM
on-module, and then your bytecodes are executed
from SRAM.
C++ and Java are in fact similar. Both are
object oriented languages, which allow you to
encapsulate your 'methods' in 'objects', which
contain both the methods and data.
Note that 'C++' is an OO expansion of 'C'.
It is true that when using the Javelin version
of Java, you have a few limitations. No garbage
collection, so you need to be careful how you
create and discard objects.
The Java run-time in the Javelin is quite
sophisticated. It allows you to run 'pseudo-
devices' along with your code -- so you can
have multiple serial ports, for instance.
If you don't want this, check out the 50-MIPS
AVR processor (see the group AVR-Chat), which
has a nice demo 'C' language, or the CCI 'C'
5 MIPS compiler for the PIC, or the Parallax hosted
50 MIPS SX 'C' compiler.
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> In a message dated 10/13/2003 12:36:05 PM Pacific Daylight Time,
> lamont@a... writes:
true?
understand
C is an
that it
PBasic. The
is EASY. I
C / C++
> Ken
was challenging the statement that C and Java were similar.
> lamont@a... writes:
> Ken
Sean T. Lamont, Chief Mad Scientist |-- lamont@a...
Zen Chemical Productions |-- http://www.zenchemical.com
Fabricators of Unnecessary Amazement
i want to make a robot
can you help me
thank you
bye
Do you Yahoo!?
New and Improved Yahoo! Mail - 100MB free storage!
hi
i want to make a robot can you help me
thank you bye
I n order to get help with a project you need to ask
more specific questions. What exactly do you want it
to do?
Do you Yahoo!?
Take Yahoo! Mail with you! Get it on your mobile phone.
http://mobile.yahoo.com/maildemo
