OT Protel Easytax libraries
Does anyone have an up to date SMD library for the old dos based
easytrax?
Regards
Tim Stockman
STOCKMAN ELECTRONICS
Computers & Communications
3 Young St
BURRA
SOUTH AUSTRALIA
Ph (08) 8892 2708
Fax (08) 8892 2788
Email tim.stockman@s...
WEB www.stockmanelectronics.com.au
Mobile 0418 811 725
Mobile EMAIL tim.mobile@s...
easytrax?
Regards
Tim Stockman
3 Young St
BURRA
SOUTH AUSTRALIA
Ph (08) 8892 2708
Fax (08) 8892 2788
Mobile 0418 811 725
I found the following (english translated from german website
http://www.ele.uri.edu/~mr/services/easytrax/easyxtnddoc1.html )
Regards peter
Extended LIBRARY for Protel EasyTrax Roger Meier 2 October 1995
(c) technical school Winterthur school of engineering
1. Description those according to standard to Protel EasyTrax provided
construction unit library EASYSTD.LIB is very extensive, but no construction
unit macros for SMD components are contained unfortunately in it.
Due to the need developed during the theses (diploma) an extended
construction unit library was provided. She is called EASYXTND.LIB and sets
themselves together from the library provided to EasyTrax EASYSTD.LIB and
components which were added again. In these components are all usual SMD
formats, as well as some additional plug formats contain. An overview of
this library is in the appendix to this document.
Installation 2,1 availability a geZIPte version of the construction unit
library EASYXTND.LIB can be downloaded here.
http://www.ele.uri.edu/~mr/services/easytrax/easyxtnd.zip
to use to be able, it must be installed for 2,2 installation in EasyPlot
around the library EASYTXND.LIB in EasyTrax correctly:
EASYSTD.LIB deletes EASYXTND.LIB and the place copies, where EASYSTD.LIB was
EASYEDIT starts in the menu ' LIBRARY ' the Submenu ' file ' selects '
easystd.lib ' through ' easyxtnd.lib ' replaces and with ENTER acknowledges
the construction unit library EASYXTND.LIB is now in EasyTrax merged and can
is used.
Oorspronkelijk bericht
Van: Tim Stockman [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cJyueE5cFsov4BIr7pQCKaYeYNq-wrG_psriziQV7ZyP1uA2wNOXVlUGss8vX7pwN-WmnYjXHK0uSSYnKsrSwImgw5CFOpy49cdnFqO2-CQ]tim.stockman@s...[/url
Verzonden: maandag 4 november 2002 20:18
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] OT Protel Easytax libraries
easytrax?
Regards
Tim Stockman
3 Young St
BURRA
SOUTH AUSTRALIA
Ph (08) 8892 2708
Fax (08) 8892 2788
Mobile 0418 811 725
