finding devices such as a Sub for 2N2222A
please try a web site called www.findchips.com enter part of the number or
all, it does a great search on most of the electronics houses that will deal
with small quantitys, its real fast and gives links to the device it found
or a web site or sometimes both.
try it you will wonder how you did without for so long.
norm
>From: "Jim Forkin" <jjf@p...>
>Reply-To: basicstamps@yahoogroups.com
>To: <basicstamps@yahoogroups.com>
>Subject: RE: [noparse][[/noparse]basicstamps] Sub for 2N2222A
>Date: Mon, 4 Nov 2002 11:08:01 -0500
>sid,
>the 2n2222 is available in plastic case as well as 2n2222 metal case. the
>2n3904 is similar and may work for your application. Check the data sheet.
>Jim
>From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=NjhYgE-ax4ZCBwVBJpKlLsDeCRm4JiABGG8DhWc2Eacm-2vtKuM3VaIPASxP5d-yKv3_uSMb]Newzed@a...[/url
>Sent: Sunday, November 03, 2002 2:30 PM
>Subject: [noparse][[/noparse]basicstamps] Sub for 2N2222A
>Need a sub for the old 2N2222A, preferably in an epoxy case- TO-92.
>Thanks
>Sid Weaver
>W4EKQ
>Port Richey, FL
>[noparse][[/noparse]Non-text portions of this message have been removed]
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
Choose an Internet access plan right for you -- try MSN!
http://resourcecenter.msn.com/access/plans/default.asp
norm
>sid,
>Jim
>Thanks
>Sid Weaver
>W4EKQ
>Port Richey, FL
