Bs2p24
I am working on a project using the BS2P24 and the L298 dual motor
controller from HVW Technologies.
I guess what I am looking for is where to find the code that will allow me to
use
DIRRS to control one of the motors
I will be hooking the BS2P24 to the dual motor controller. One 12 V DC motor
will be programmed to rotate a fixed number of degree's (120) and return to its
starting point, rest several seconds, rotate 120 degrees, rest, and return. At
a
certain point of the rotation, I would like to allow for a switch to be
activated
which will control another 12 v dc motor to which an arm is attached, this
motor, is rotating in only one direction, but I would like it to stop for
several
seconds, half way through its rotation and then continue its rotation, rest and
rotate again.
I am not sure if I made this clear or not. I just don't know where to begin to
look for the codes.
John lathram
use
a
activated
several
rotate again.
look for the codes.
John lathram
