best way to get PC boards from ExpressPCB to a board h...
In a message dated 10/29/2002 12:44:40 Eastern Standard Time,
ben@l... writes:
> I get around the grid problem on printouts by:
> Where there are no tracks, I always put in a ground plane if possible. This
> also reduces the amount of copper that needs to be etched away.
> Therefore, if there are any dots, they are few, and I find they do not get
> in the way anyway.
> cheers,
Hi, Ben
All you have to do is go to View/Options/Colors and make the grid color the
same as your background color (white).
Sid
ben@l... writes:
> in the way anyway.
> cheers,
Hi, Ben
Sid
I made the background and grid both white and the grid shows through the
tracks. I tried it with black background and black grid and got the same
results.
the
http://www.olimex.com/pcb/ lists several vendors for software.
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JTxuQHf1AViLO3wWQ5LAt8OkQW_DMG913ws_7Db_c-C7oP4GmMglTE2Zk330E56ZAqfYowHnXZs]Newzed@a...[/url
Sent: Tuesday, October 29, 2002 12:52 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: best way to get PC boards from ExpressPCB
to a board h...
ben@l... writes:
This
> in the way anyway.
> cheers,
Hi, Ben
Sid
