Eagle ( was Re: best way to get PC boards from ExpressPCB to a board house
I think many of us have tired Eagle.
and most never got over the sheer cliff of a learning curve.
I would have hoped they would have come up with a tutorial
that made it easier to learn.
seems the buisness model of giveing away the low end
did not make it the beginners package.
Dave
--- In basicstamps@y..., "jbirnsch" <jbirnsch@v...> wrote:
> Stampers,
> If you all are looking for a free PCB editor and you have a Mac
then
> look no further. Osmond PPC is a free PCB editor. Works like a
charm.
> I output a mirrored Postscript file and then convert that to PDF
then
> print to laser printer. I have made a dozen or more boards with
this
> tool on my iBook and using DynaArt toner transfer paper. It can
> import net lists but I usually draw the traces by hand like Express
> PCB software. Building new parts is easy. Just set your pad size
and
> your grid spacing and build your parts. I've had good luck with
fine
> traces(10 mil) and small parts such as 0603 resistors and TSSOPS
> using a Monokote iron with the max heat setting and light pressure.
> The key is not too much pressure to squish the traces and enough to
> make the toner stick to the board. I can send pics of the boards
that
> I have made with this package if you like.
> http://www.swcp.com/~jchavez/osmond.html
> Now if you are a Windoz user then the best I can suggest would be
> Eagle Cad. but there is limitations with there free verson. Trying
to
> clean up the ExpressPCB files are a waste of time - been there and
> tried that.
> http://www.free-pcb-software.com/html_uk/uk_service_1.htm
> Jason
> --- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> > You can turn off the grid dots on the screen, but I have not
> verified they
> > go away on the printed copy.
> > > I just printed out something with mine (V2.6.2) and it
> > > also printed the grid dots, therefore making it
> > > unusable for photo trasfer...Is your version older?
Dave
> Stampers,
then
charm.
then
this
and
fine
that
to
> tried that.
> Jason
> verified they
and had a decent 2-layer board done in a couple of hours.
*really* like a schematic capture with an auto-router. MUCH fewer
mistakes. Granted I have used a different package some years back,
but Eagle is straightforward in my eyes.
> I tried Eagle also, and got nowhere. I downloaded the PCB Express
software
could use some work, but I found eagle very easy to manipulate.
> Dave
> > Stampers,
> then
> charm.
> then
> this
> and
> fine
> that
> to
> > tried that.
> > Jason
> > verified they
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
straightforward. There are a few odd things like "smash" to detach
text from a device. Also a couple parts of the tutorial aren't as
clear as they could be but... So far I'm finding it pretty easy.
--- In basicstamps@y..., "Sean T. Lamont .lost." <lamont@a...>
wrote:
> Really? after about 2 hours, I found eagle very intuitive. The
autorouter
> > Dave
> > > Stampers,
> > then
> > charm.
> > then
> > this
Express
> > and
> > fine
pressure.
enough to
> > that
be
Trying
> > to
and
> > > tried that.
> > > Jason
> > > verified they
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
(ServNet)
Bremerton
already done in ExpressPCB.
I find the librarys not very intuitive. Believe it or not, I am
still looking for a simple 1/4 watt resistor.
Once you understand the concept of placement it starts to get easier.
(learning curve)
Like I said, Express PCB is so much easier, many use that as the
first step in learning. then are stuck with the drawings that are
somewhat pricey to convery.
and regarding specifc chips, if there is a close match, Eagle does
allow creating a chip with your specifics very easy. That is one
nice feature.
As yet, I have not found the tutorial, just a brief slide show style
introduction.
Dave
autorouter
> > Dave
> > > Stampers,
> > then
> > charm.
> > then
> > this
Express
> > and
> > fine
pressure.
enough to
> > that
be
Trying
> > to
and
> > > tried that.
> > > Jason
> > > verified they
(ServNet)
Bremerton
Sent: Friday, November 01, 2002 3:31 AM
Subject: [noparse][[/noparse]basicstamps] Eagle ( was Re: best way to get PC boards from
| I spent a couple hours putting together a schematic of a board
=> Have a look into the RCL (R=resistor, C=capacitor and
L=inductors) library...
easier.
| (learning curve)
=>I've seen on this list that obtaining a correct printout is a bit
tricky with Express PCB...
| nice feature.
| introduction.
=> Have a look there :
http://www.cadsoft.de/cgi-bin/download.pl?page=/home/cadsoft/html_publ
ic/download.htm.en&dir=pub/program/4.0
=> ...and get the tutorial-eng.pdf... it's a 57-page tutorial...
| Dave
Phil.
try searching for R-US for the American symbol or R-EU for European. Also
look at RCL library 0207/10. There are also all the surface mount devices
in the libraries. Several additional libraries are available for download
at the cadsoftusa.com web site.
Good luck,
Jim
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=anTyapTWsEXazUEG7RIRPWc5jcxpEMgU-QBLjyTB1KudTHSQeTM8w6KtDzGIPqZtJz1sm2RXHNT7p1E]davemucha@j...[/url
Sent: Thursday, October 31, 2002 9:31 PM
(learning curve)
nice feature.
introduction.
Dave
autorouter
> > Dave
> > > Stampers,
> > then
> > charm.
> > then
> > this
Express
> > and
> > fine
pressure.
enough to
> > that
be
Trying
> > to
and
> > > tried that.
> > > Jason
> > > verified they
(ServNet)
Bremerton
new schematic capture and auto router but I've not been through it
completely yet. In playing one of my new complaints is the size of the
component library. All parts in one list, damn long. It could use some
additional tweaks and feature but still a good package. Easy to use and
good for what I do. The cost is high up front but the boards with no
silkscreen or solder mask is three days and not too bad.
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lp-DClmh6Z_Y380hYD6i5Rs9ezU1gW7nXiMqhLuXMFxupY_s2ZcPY68ly5fwa0_AzWWBLsKKK47hYtkt2A]davemucha@j...[/url
(learning curve)
nice feature.
introduction.
Dave
autorouter
> > Dave
> > > Stampers,
> > then
> > charm.
> > then
> > this
Express
> > and
> > fine
pressure.
enough to
> > that
be
Trying
> > to
and
> > > tried that.
> > > Jason
> > > verified they
(ServNet)
Bremerton
some new boards to do and would rather make a board from a schematic.
I was really pleased with the service from Express PCB -- I submitted my
layout online and had high-quality boards in my hot little hands in a couple
of days. They solder well and I had no problems with holes sized wrong,
mis-drilled, etc...
The other PCB programs may be alot fancier and do alot more, but for someone
with no PC-based schematic or PCB layout experience, the Express PCB
software is great.
> I have a copy of the new beta from ExpressPCB. It is supposed to include
a
