USB to Serial Adapter - Programs the Stamp but doesn''t work ?
This is exactly the reason I decided to make my own adapter in the end.
All of these adapters from Belkin, Keyspan, etc. never seem to be 100%
compatible, and I was starting to get so annoued that I thought "Stuff it!
I'll make my own."
I've tested mine OK on:
Programming the BS2
Communicating with the BS2 during runtime
Using an RS232 modem for surfing the web
Communicating with a Palm Pilot
http://www.lennard.net.nz/electronics/usbtors232.html
> From: "rds2112geo" <rds.presto@g...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Mon, 28 Oct 2002 16:26:31 -0000
> Subject: [noparse][[/noparse]basicstamps] USB to Serial Adapter - Programs the Stamp but doesn't
> work ?
> Hi all.
> OK, I know, the whole USB-to-Serial Adapter thing has been discussed,
> but I haven't seen my particular problem... Here goes:
> My I-Concepts USB-to-Serial adapter ($28 at CompUSA, marketed towards
> PDA users) works FINE as far as seeing the Satmp2 and programming it.
> However, when I run a program using serial commands from the PC to the
> Stamp, the I/O doesn't work.
> I've tried shorting out pins to eliminate handshaking (as described in
> the manual), I've tried slower baud, and endless combinations of
> 8,N,1,none, etc.
> The program I'm using is from Stamps In Class - the one that uses
> LabVIEW to talk to the Basic Stamp - "LabView Interface for the BASIC
> Stamp". The BS code and LabVIEW vi work great through a normal com
> port, but not when I use the USB-to-Serial adapter.
> I have used this adapter with other programs that use LabVIEW to
> non-Basic Stamp stuff and it communicates just fine.
> Again, this adapter programs the stamp fine - just doesn't do serial
> communications. (?)
> Any ideas?
> of the message will be ignored.
I'll make my own."
Programming the BS2
> work ?
> Hi all.
> 8,N,1,none, etc.
> communications. (?)
> Any ideas?
