USB to Serial Adapter - Programs the Stamp but doesn''t work ?
>I've tried shorting out pins to eliminate handshaking (as described in
>the manual), I've tried slower baud, and endless combinations of
>8,N,1,none, etc.
Have you tried putting the capacitor in series in the line from DTR
to ATN (pin 4 on the DB9)? That is the most common way that this
kind of problem is resolved.
pin 4 of DB9
ATN pin 3 on BS2ic
0.1uF
>8,N,1,none, etc.
pin 4 of DB9
ATN pin 3 on BS2ic
0.1uF
