Decode a SONY IR Reomte
Decoding isn't tough; you can refer to my August 2001 article in Nuts & Volts
magazine and detail information on the Parallax web site (see the Resources
section, under "Weekend Special" downloads).
Recreating the signal with a BS2 is going to be much more tricky. I'm pretty
sure you're going to need an external modulator for the LED (a 555 timer will
do).
-- Jon Williams
-- Parallax
In a message dated 10/28/02 10:02:54 AM Central Standard Time,
jleung00@n... writes:
> Hi Stampers
> I would be grateful if anyone can suggest a good article on decoding a SONY
> IR remote and others, and re-produce the IR signal by a BS2.
> Thanks a lot.
> John
do).
-- Jon Williams
-- Parallax
> Hi Stampers
> Thanks a lot.
> John
Thanks a lot.
John
