SumoBot
Greetings All!
I'm at my wits end! I just received two sumobots, I have put them
together, sans the missing cables, but I cannot get the servos to
turn. The simple program makes them buzz but that is all.
What is missing?
Any and all suggestions are welcome!
I tested the servos on an old boe bot and they work.
Chris
What is missing?
Chris
The program??
Mike B.
Sent: Saturday, October 26, 2002 3:11 PM
Subject: [noparse][[/noparse]basicstamps] SumoBot
> Greetings All!
> What is missing?
> Chris
board problem.
Are the batteries weak? Could be the Stamp is resetting when you try to run
them. If the board has a beeper or LED on it, modify the code to flash the
LED or beep when the program first starts up. If it keeps doing this over
and over the Stamp is resetting.
> What is missing?
I wrote the SumoBot text and it was tested by several employees, so I'm
pretty sure that part is good.
* Are you plugging the servos into write place and orientation?
-- I've plugged them in backwards myself
-- the black wire goes towared the outside edge of the PCB
* Are your batteries okay?
* Did you make any changes to the demo code that would affect the servos?
-- Jon Williams
-- Parallax
In a message dated 10/26/02 5:12:38 PM Central Daylight Time,
cnbnichols@r... writes:
> Greetings All!
> What is missing?
> Chris
1 only powers the Stamp.
-- Jon Williams
-- Parallax
> Greetings All!
> What is missing?
> Chris
terminals on both. When I run the following code I get nothing on
both. I confirmed that the black wire is out.
I did get the servos to run on another board with the same code, but
they did not run correctly. That is, the both ran in opposite
directions no matter what the pulse width was for each, at certain
pulse widths they just buzzed.
Here is the code cut and pasted from the editor:
[noparse][[/noparse]Title]
' Mini-Sumo 2.1 : SumoBot Motor Test
'{$STAMP BS2}
[noparse][[/noparse]I/O Definitions]
LMotor CON 13 ' Left servo motor
RMotor CON 12 ' Right servo motor
[noparse][[/noparse]Constants]
LFwdFast CON 1000
LFwdSlow CON 800
LStop CON 750
LRevSlow CON 700
LRevFast CON 500
RFwdFast CON 500
RFwdSlow CON 700
RStop CON 750
RRevSlow CON 800
RRevFast CON 1000
[noparse][[/noparse]Variable]
pulses VAR Byte
[noparse][[/noparse]Initialization]
Start_Delay:
Pause 2000
[noparse][[/noparse]Main Code]
Main:
FOR pulses = 1 to 125
PULSOUT LMotor, LFwdSlow
PULSOUT RMotor, RFwdSlow
PAUSE 20
NEXT
FOR pulses = 1 to 110
PULSOUT Lmotor, LStop
PULSOUT Rmotor, RFwdSlow
PAUSE 20
NEXT
FOR pulses = 1 to 50
PULSOUT LMotor, LFwdFast
PULSOUT RMotor, RFwdFast
Pause 20
NEXT
FOR pulses = 1 to 30
PULSOUT RMotor, RRevFast
Pause 20
Next
Hold_Position:
PULSOUT LMotor, LStop
PULSOUT RMotor, RStop
Pause 20
GOTO hold_position
--- In basicstamps@y..., jonwms@a... wrote:
> Chris:
I'm
servos?
> -- Jon Williams
> -- Parallax
the sumo bot has break in the ground circuit so you can monitor the motor
current. You either jumper it with a wire or with a low value, high wattage
resistor.
> I have two bots, both with fresh batteries, I get 6.+ vdc at the
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZqkgqYHSJmfw3LV9wTtxTgppzUuFptoo1Ym9ALEPiLuWNdirrpABZJWFS2HixGJiKckl8kiakM1E2A]daweasel@s...[/url
Sent: Sunday, October 27, 2002 8:08 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: SumoBot
Did you remember the jumpers on the board for the servo ground?? I believe
resistor.
There is nothing in the instructions that describes that and the schematic
indicates that they are connected.
Thanks!
Chris
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=53-t3sS0gCXvHqJICbNSPUIz9WXmm7Sy4vIF-fDdmlQJIND8c6yHO3sl16UTtl3-pL4ArFjyhucD]daweasel@s...[/url
resistor.
for you.
-- Jon
In a message dated 10/27/02 7:39:19 AM Central Standard Time,
> I figured it out, I needed a jumper between Vs1 and Vss and Vs2 and Vss.
> Thanks!
> Chris
glanced at the board and heard Jon Williams mention them when he was showing
off this product at our club meeting. If I remember right, they are on a
couple of single-row sockets somewhere near the servo connectors.
You did mention one of the two sumo bots worked, so I would compare both
boards and see if you see anything different.
> There are no instructions for jumpers, where would they go?
wattage
> resistor.
and Vs1, and Vss and Vs2. Vs1 and Vs2 are the ground connections to the
servos.
Why are the disconnected, you wonder? Well, advanced users may want to
monitor the motor current to detect stall. How? You can replace the jumpers
with low-value precision resistors and measure the voltage across these
resistors with a two-channel ADC.
-- Jon Williams
-- Parallax
In a message dated 10/27/02 8:01:31 AM Central Standard Time,
> From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aruiz6HoHH41ToS6MRzk0CIhfqWKF2Ch9hEYayqBXvgTctgLwIsLdNyYSrFWyW05yXKIyAtFtWHLE8bfgEA]daweasel@s...[/url
> resistor.
