Javelin and I2C
Hi!
I have a SRF08 (http://www.robot-electronics.co.uk ) and a Javelin-Stamp
but I cant get it run.
The problem is the I2C bus. I use the I2C.class class, but it does not
respond in any way.
Does anyone have an example?
There IS a sample for BS2 (in basic), unfortunately I never programmed
in BASIC, so I am not sure if I understand it.
Best regards,
Roland.
Roland Schaffer
respond in any way.
Best regards,
Roland.
Roland Schaffer
Am Mit, 2002-10-23 um 10.17 schrieb John Murphy:
> Be sure that you have pullup resistors on your SCL and SCA pins.
> From: roland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TzRxaDCWqgH_d6TdXnqj4QBl5uY7V989dYdn8EkiKNKHoP34hh7fUU7D9nG7SOECFnXd3ZNgiBOVuM1q]roland@x...[/url
> Sent: Tuesday, October 22, 2002 11:58 PM
> Subject: [noparse][[/noparse]basicstamps] Javelin and I2C
> Hi!
> respond in any way.
> Best regards,
> Roland.
> Roland Schaffer
> Body of the message will be ignored.
Xiberg softworX
Hochlastserver - Synthetische Sprachen - Systemprogrammierung
Unix System V - Linux - HP-UX - QNX - UnixWare - BSD
http://www.xiberg.com roland@x...
(start, write byte, read byte and stop) for general-purpose I2C
communications. I can tell you that it works -- because I wrote it. What
the programmer has to do is create a class for the desired object that
references a previously-instantiated I2C bus object and calls the various
methods in the I2C class to handle higher-level work.
I have a couple SFR08s but haven't connected them yet. I have, however, used
the I2C class to talk to the Devantech CMPS01 which also uses I2C. Contact
me off-list and I will send you that code.
-- Jon Williams
-- Parallax
PS: You are aware that there is a separate Javelin support list, right? It's
a private [noparse][[/noparse]not on Yahoo] list that can be accessed through
www.javelinstamp.com.
In a message dated 10/23/02 2:02:43 AM Central Daylight Time,
roland@x... writes:
> Hi!
> respond in any way.
> Best regards,
> Roland.
From: roland [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J5kbi0bMco61bU1bjQcUJCFUIwvcxvsRKz9Ng9dg37932X350veEhk0VWKkshZKN4DDuwCGmwdD8]roland@x...[/url
Hi!
respond in any way.
Best regards,
Roland.
Roland Schaffer
