SPSTR modifier
ATTN: Tracy Allen
I looked all over the web site and in the 2.0b manual but found nothing. Then
I looked in the Stamp Eidtor (V1.32) help file and found the information on
SPSTR under the SERIN command. Pretty slick stuff.
God I love these Stamps..
Mike B.
Mike B.
Here is a code fragment that I have been using...
StringLength CON 16
charString VAR Byte(StringLength)
SERIN TapeIn, N1200, 2000, NoTape, [noparse][[/noparse]STR charString\StringLength\"i"]
I now want to stick the incoming string into scratchpad memory.
It is my understanding that I should use the SPSTR modifier.
Where can I find documentation on SPSTR?
How can I use SPSTR so my string gets padded with NULLs and input
stops at "i"?
Thanks!
Take care,
Frank
of bytes, and does not have and ending character like STR that will pad
unused bytes with NULL characters. If you want to use the Scratchpad
RAM as a buffer, you'll need to accept fixed-sized blocks of data.
You can find information about SPSTR in the online help file (let me
remind everyone that the Help file is the best first place to look for
information on PBASIC syntax and functions).
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OY_9GtMmgcw9k0plOTAXUTYiN16G0A601WSKbnsoXdSzDnK24kzfmSoo9CSMtu6po0Eqt0kIspJcYwupvX_kuBQ]franksmith512@y...[/url
Sent: Sunday, April 11, 2004 11:26 AM
Subject: [noparse][[/noparse]basicstamps] SPSTR Modifier
Hi All!
StringLength CON 16
stops at "i"?
Thanks!
Take care,
Frank
Sounds like the SPSTR modifier will work for what I am doing if only
I could find that online Help file you mentioned.
I looked at parallax.com support
http://www.parallax.com/html_pages/tech/index.asp
and downloads
http://www.parallax.com/html_pages/downloads/index.asp
Apparently, I am missing something.
Is there a link on the Parallax site to the Help file?
Take care,
Frank
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> SPSTR is not quite as flexible as STR -- it waits for a specified
number
pad
Scratchpad
for
> -- Jon Williams
> -- Dallas Office
> From: franksmith512 [noparse][[/noparse]mailto:franksmith512@y...]
> Hi All!
> StringLength CON 16
> stops at "i"?
> Thanks!
> Take care,
> Frank
Yes, you are. The help file is part of the editor. Simply click the tool
bar and select help and look in the command reference section for the
commands you desire..
Mike B..
Sent: Sunday, April 11, 2004 2:25 PM
Subject: [noparse][[/noparse]basicstamps] Re: SPSTR Modifier
> Jon,
> and downloads
> Take care,
> Frank
> number
> pad
> Scratchpad
> for
> > -- Jon Williams
> > -- Dallas Office
> > Hi All!
> > StringLength CON 16
> > stops at "i"?
> > Thanks!
> > Take care,
> > Frank
> Yahoo! Groups Links
Just click on the little book icon on the toolbar, or select Help >>
Contents....
On the left you'll find a tabbed area. Select search, enter SPSTR in
the input field, and then click "Show Topics." What you'll see is that
it can be found in all the serial stream input functions (SERIN,
DEBUGIN, I2CIN, etc.).
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=To7hVNgoXQt5mSYrbJoMtJyVwkh88gMIt-W0e483oqzjgvCEWPK0y5I_k9w7Mn9auVd8sGEPiZCxOQ_j2pE7Pqgu]franksmith512@y...[/url
Sent: Sunday, April 11, 2004 1:26 PM
Jon,
and downloads
Take care,
Frank
It just never crossed my mind that there was documentation better
than that found at the parallax site.
I am in the habit of using Basic Stamp Manual 2.0c.
Am glad to see more current documentation. Especially because I have
the BS2pe which isn't covered in the older docs.
Frank
wrote:
> Yes, we've very cleverly hidden the online help for our compiler. [noparse];)[/noparse]
> Contents....
in
that
> -- Jon Williams
> -- Dallas Office
> Jon,
only
> and downloads
> Take care,
> Frank
the cracks last time through). The BS2pe is a lower-power version of
the BS2p and has a couple extra goodies -- you can find those details in
the Help file and they will also be covered in the manual update. As
you can imagine, electronic documents are easier to update than our big
printed manual.
-- Jon Williams
-- Dallas Office
From: franksmith512 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1x3ASIrOTDzxu4h2ZNbVNLin4n9MZG4KRXi3CL4D22D2aP4BJzsZufhOeN5-K-awV0wmdMkQLTf85NCRN2qTw4nl]franksmith512@y...[/url
Sent: Sunday, April 11, 2004 9:43 PM
Jon,
Frank
Thanks for the info. Hope others read this thread and know to read
the Help w/in the compiler. It is so nice to see the BS2pe mentioned
in a manual.
Thanks for all the help!
Take care,
Frank
wrote:
> We're in the final stages of updating the manual (SPSTR slipped
through
of
details in
As
big
> printed manual.
> -- Jon Williams
> -- Dallas Office
> Jon,
have
> Thanks,
> Frank
