Safe to Assume?
Question about "buffered" serial communications.
I have a serial controlled UHF radio That I want to "talk" to. The manual is
a bit vague as it is not the EXACT manual for this radio but I think in this
case it's close enough.
The radio uses RS-232 to communicate with a host processor. Got that working
so far. The radio has a 96 character buffer. The radio also use CTS/RTS for
handshaking. The manual states that the handshake goes up when the buffer is
3/4 full and goes back down when the buffer is emptied to 1/4 full. The
handshake does not appear to flip with every character. Question is this. If I
simply do a loop to read characters one at a time into an array will the buffer
in the radio "wait" until the stamp does a SERIN or is there a possibility the
radio will spit out characters while I am busy handeling the last character? In
other words will I get out of sync and if so how should I handle this situation
to make sure I get all the characters in the buffer??
(Don't ya just love RS-232? <g>?)
Mike B.
Mike B.
done some Icom or CV-something interface for the opto-electronic
Scout.
Larry
To: "Basic Stamps" <basicstamps@yahoogroups.com>
Sent: October 19, 2002 11:00 AM
Subject: [noparse][[/noparse]basicstamps] Safe to Assume?
The manual is a bit vague as it is not the EXACT manual for this
radio but I think in this case it's close enough.
Got that working so far. The radio has a 96 character buffer.
The radio also use CTS/RTS for handshaking. The manual states
that the handshake goes up when the buffer is 3/4 full and goes
back down when the buffer is emptied to 1/4 full. The handshake
If I simply do a loop to read characters one at a time into an
array will the buffer in the radio "wait" until the stamp does a
SERIN or is there a possibility the radio will spit out
this situation to make sure I get all the characters in the
buffer??
Mike B.
from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
Nope, this is a commerical "data modem" that happens to be in the 420 Mhz
ham band. There are no operator controls on the radio and I wondering if a
buffered system just blindly spits out the data and expects you to always be
ready to recieve the data or not. I only have half the comm link available
at this time as I haven't built the remote system yet but I wanted to get a
leg up on the comm portion for the local side. Been trying to come up with
a way to send a string to the local unit with the other radio. Perhaps
"Hyper Terminal" connected to the other radio can do it. So far as I can
tell there Hyper sends each character as it is typed, not much help to test
what I am try to nail down at this time.
Any ideas??
Mike B. W6FFC
Sent: Saturday, October 19, 2002 2:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] Safe to Assume?
> Is this for the Icom interface cv? or something like this. I have
> Scout.
> Larry
> From: "Mike Blier" <w6ffc@p...>
> buffer??
> Thanks
> Mike B.
