Smallest Stepping Motor
Hello all,
Can you please give me directions on what the smallest size stepping
motor that is commercially available? I'm looking for a stepping
morot that is no more than 2"x1" (LxW). Not sure if there even
available in this size. If so, could you please let me know where I
can purchase one. Thanks a million!!!
(mounting plate) by 1/2" thick. I think I bought it from DigiKey.com. The
model number is "STP-42N196S" but I think it is no longer in mfr however
they (Digikey) have many others to choose from and they all have data sheets
on line.
MIke B.
Sent: Saturday, October 19, 2002 9:57 AM
Subject: [noparse][[/noparse]basicstamps] Smallest Stepping Motor
> Hello all,
>Hello all,
Look in your junk pile and grab a dead 3.5" floppy drive. The stepper
motor that moves the head back and forth is a small stepper about 1"
diameter by about 1" long.
If you don't have any dead floppy drives handy, just visit your friendly
neighborhood computer shop - they probably have a few dozen sitting around.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
--- In basicstamps@y..., Dwayne Reid <dwayner@p...> wrote:
> At 04:57 PM 10/19/02 +0000, kmalhas wrote:
> >Hello all,
> dwayne
What is the step size in these motors? I would guess 1.8 degrees, for
200 steps/rev, but I could be wrong.
Dennis
From: Dwayne Reid [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xyGI_dY0f4cJn137GIWMu5wwpTYXbUXBpVg-18r16nlSreyNPj3BtUT_LzqNIOyt7ppNM_4JmMqiwMqi0hgXbCE]dwayner@p...[/url
Sent: Saturday, October 19, 2002 11:05 AM
Subject: Re: [noparse][[/noparse]basicstamps] Smallest Stepping Motor
>Hello all,
>motor that is commercially available? I'm looking for a stepping morot
>that is no more than 2"x1" (LxW). Not sure if there even available in
>this size. If so, could you please let me know where I can purchase
around.
dwayne
www.allelectronics.com
www.jameco.com
all come to mind, they were surplusing out little 10mmX16mm round bipolar
stepping motors used in some kind of a camera focusing unit. Some come with
the focusing unit, some without. They also had the same motors in some kind
of a tape head positioning device as well.
Those are the smallest steppers that I know about.
From: kmalhas [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e28ZMbRxZC3PEJ47CUaCWbxMiBi5o7AJ2m14JE-apknTL6AInY-epYnrKWNk7BN9cFm23FVvJTu0]kmalhas@y...[/url
Sent: Saturday, October 19, 2002 11:58 AM
Hello all,
there is a stepper motor in a Swatch watch which is well under that size.
It's small enough that you could probably run it directly off the Stamp pins.
-Larry
In a message dated 10/19/02 5:12:14 PM Pacific Daylight Time,
basicstamps@yahoogroups.com writes:
> Hello all,
Is 3mm small enough ?
Check out:
<www.smoovy.com>
kmalhas wrote:
> Hello all,
I have two pairs of gear motors and they work fine off of DC voltage.
No stepper motor driver needed.
From: Don Zacharie [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aBFdZ8fOTkojNqKWejd9z4VFFKliU8lAPf2cVVevargEkwfxkWEm1ZH2OSHuzHtq-2f7X235SA]donzach@a...[/url
Sent: Saturday, October 19, 2002 11:56 PM
Check out:
<www.smoovy.com>
kmalhas wrote:
> Hello all,
Here is one of the smaller ones. http://www.arsape.ch/pdf/motors/eAM_0820.pdf
I think µ-Mo sells them: http://www.micromo.com/
At 04:57 PM 10/19/2002 +0000, you wrote:
>Hello all,
_________________________________
Mike Walsh
walsh@i...
for a medical device. But I recommend following Mike Walsh's reference
example because it includes a full set of specifications, such as step
size and holding torque, that are crucial to most applications, as
opposed to just physical size.
Dennis
From: Mike Walsh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=weDZecuNgF1qMHCID08PqDLMEwi3Rf1c6_8oUn61W7OP8oB3py6EAP-dS2HY01kef_vACNg89A]walsh@c...[/url
Sent: Monday, October 21, 2002 9:08 AM
Don't know if it's the smallest. I have used Arsape motors with great
success! Here is one of the smaller ones.
>Hello all,
