R/C Receiver - BS2 Input Connection
Hello Everyone
I am attempting a small BS2 project where I would like to control BS2
inputs with the output of a simple R/C reciever. The R/C control used
is a toggle switch on the transmitter. When the switch is one way it
drives the servo to one extreme (CW) and when the switch is toggled
in the direction, it drives the servo to the other (CCW). I assume
the receiver is outputting a 1.0 ms pulse in one state and a 1.5ms
pulse in the other. I would like to know which position the switch is
in so I can run separate servo sequences. I tried using the following
code with the PULSIN command:
pulse var word
main:
pulsin 0, 0, pulse
debug "Pulse = ", dec pulse, cr
If Pulse > 750 then other
debug "pulse is greater than 750"
other:
debug "pulse is less than 750"
pause 450
goto main
I tried to move the pot on the transmitter to see the change in debug
to no avail - all I got was randem values for 'pulse'
The things I am not sure on are: 1/if connecting the signal line
directly to the stamp is the right thing to do and 2/what the best
command is to read the PWM signal from the receiver so I can follow
through to get the stamp to do one thing or another.
If someone could shed some light, it would be appreciated.
Kim
pulse var word
main:
pulsin 0, 0, pulse
other:
pause 450
goto main
Kim
First of all, the range of most R/C servos is a positive going pulse going
from 1.0 to 2.0 ms with 1.5 ms being the servo center position. The pulse
from the R/C reciever is repeated at a rate of 50 times per second.
Your pulsin command shoud be as follows:
pulsin 0,1, pulse 'The one indicates a positive going pulse (ie: 0
to 1)
You didn't specify which chip you are using (it matters) so I don't know if
your values are correct for the "if then" statement.
The other problem I see in your code is the delay. The loop must be
checked in less than 20 ms (1 divided by 50) assuming you want to constantly
check the pulse in order to "see" each pulse. To see if the switch is
thrown simply check for pulse width of greater than say 1.5 ms. You can
adjust these numbers to make it catch the switch position every time.
I am using 8 channels of servo control in a R/C project and have had
great sucess with the Stamps and servos. If you need anymore help let me
know.
Clear as mud now? <g>
MIke B.
Sent: Saturday, October 19, 2002 5:25 AM
Subject: [noparse][[/noparse]basicstamps] R/C Receiver - BS2 Input Connection
> Hello Everyone
> pulse var word
> main:
> pulsin 0, 0, pulse
> other:
> pause 450
> goto main
> Thanks
> Kim
statement to this:
PULSIN 0, 1, pWidth
pWidth = pWidth * 2
DEBUG DEC (pWidth / 1000), ".", DEC3 pWidth, " milliseconds"
The PULSIN function returns a value in 2 microsecond (1/1000 of a
millisecond) units, so you need to multiply by 2 to get microseconds. The
DEBUG line will make a nice output so, when centered, you should see
something like this:
1.500 milliseconds
Leave the PAUSE 450 out since the DEBUG causes a small delay and the receiver
should be sending updates every 20 milliseconds or so.
-- Jon Williams
-- Parallax
In a message dated 10/19/02 7:26:09 AM Central Daylight Time,
krcnz@y... writes:
> Hello Everyone
> inputs with the output of a simple R/C receiver. The R/C control used
> pulse var word
> main:
> pulsin 0, 0, pulse
> other:
> pause 450
> goto main
> Thanks
Thank you both for your help. I can see where some of my fundamentals
are wrong. I have tried Jon's code as my inital task is to get the
R/C receiver talking and BS2 Stamp listening. Unfortunately I got
debug results that I could not make heads nor tails of.
In any position I got alot of 0.002, 0.004 readings and every once in
a while (somewhere between the 10th and 30th sample) I got a 1.544
(in centre), 1.228 (one direction) and 1.852 (other direction). So
this is something, but immediately after the samples with the numbers
I expected, I get a sample of 13.500 or thereabouts - always over
13.000. This happens in any position, so I'm not sure what to look
for next. The receiver is a JR 2 Channel AM unit, I'm not sure if JR
have a propriety signal system??? To check normal operation I ran a
servo in parallel with the single signal wire going to my input port
and the servo worked fine with movement of the transmitter. I also
unplugged the input wire to check that the numbers were coming from
the receiver and not just random off the stamp (for whatever reason)
and all of the smaples went to zero.
Any further ideas?? (This is only my second week with using the
stamp - or any kind of microcontroller and I'm a little perplexed as
to which way to jump next)
Thank you in advanced
Kim
--- In basicstamps@y..., jonwms@a... wrote:
> Since the RC receiver outputs a high-going pulse, change your
PULSIN
> statement to this:
> PULSIN 0, 1, pWidth
> pWidth = pWidth * 2
microseconds. The
see
> 1.500 milliseconds
the receiver
> -- Jon Williams
> -- Parallax
> krcnz@y... writes:
> > Hello Everyone
BS2
used
it
toggled
assume
1.5ms
switch is
following
> > pulse var word
> > main:
> > pulsin 0, 0, pulse
> > other:
> > pause 450
> > goto main
debug
best
follow
> > Thanks
Mike B.
Sent: Saturday, October 19, 2002 4:27 PM
Subject: [noparse][[/noparse]basicstamps] Re: R/C Receiver - BS2 Input Connection
> Hello Jon and Mike
> Kim
> PULSIN
> > statement to this:
> > PULSIN 0, 1, pWidth
> > pWidth = pWidth * 2
> microseconds. The
> see
> > 1.500 milliseconds
> the receiver
> > -- Jon Williams
> > -- Parallax
> > krcnz@y... writes:
> > > Hello Everyone
> BS2
> used
> it
> toggled
> assume
> 1.5ms
> switch is
> following
> > > pulse var word
> > > main:
> > > pulsin 0, 0, pulse
> > > other:
> > > pause 450
> > > goto main
> debug
> best
> follow
> > > Thanks
look at it with?
-- Jon Williams
-- Parallax
In a message dated 10/19/02 6:27:07 PM Central Daylight Time,
krcnz@y... writes:
> Hello Jon and Mike
connected to it is stable and responds as expected. I will set out
over the next couple of days to if I can get another receiver to have
a look at. From what you and Mike have replied to, everything should
have worked honky dorey.
I'll let you both know how I get on.
Thank you
Kim
> Perhaps you've got a bad output from your receiver. Do you have a
scope to
> look at it with?
> -- Jon Williams
> -- Parallax
> krcnz@y... writes:
> > Hello Jon and Mike
fundamentals
the
once in
1.544
So
numbers
look
JR
a
port
also
from
reason)
as
I recently hooked up a rate gyro to a BOE (and then connected that to
the IFI robot controller). You can find commented code at:
http://www.madoverlord.com/Robots/PWM.t
that should give you the clues you need. Even has a pic of the setup.
R
of nonsense data. I'm not an RC guy, so I don't have the equipment to test
this myself. Perhaps another list member can assist.
-- Jon Williams
-- Parallax
In a message dated 10/19/02 8:23:18 PM Central Daylight Time,
krcnz@y... writes:
> No I dont have a scope. I thought the same myself, but a servo
> Thank you
> Kim
More importantly whose rate gyro did you use, and where did you get the
thing?
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> From: Robert Woodhead [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qdhl6S6MWU2FoCX-pMnVdw6qU6vc71Nn2R54Iwlmti44xN7Y_CAQEampd6Y6yU5ZV1LmgWt8e5_g_A]trebor@a...[/url
> Sent: Saturday, October 19, 2002 9:20 PM
> R
and Body of
