Stache: BASIC Stamp Field Programmer
I've got a Stache BASIC Stamp Field Programmer that is brand new,
and I am looking to either sell it or even consider a trade
depending on what it is. If anyone is interested, please contact me
off list at charleybot@y... , or you can go to
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1777400496&rd=1
Do you know?
James
> that is brand new,
> consider a trade
> go to
> from the same email address that you
> subscribed. Text in the Subject and Body of
> the message will be ignored.
1.31 or above editor from Parrallax? The older units (the ones from DigiKey
etc.) will not work with the latest Parrallax editor! If it is the newer unit
I would be interested.
EME Systems has a generous postage-only upgrade policy:
http://www.emesystems.com/stache.htm
If you purchased the Stache in 2002 and did not receive the version
1.6 firmware, we will also cover the return shipping. It takes a
while to get the new firmware into the distribution pipeline.
Stache firmware version 1.4 supports the BS2p, but you have to use it
with version 1.1 of the IDE (STAMPW.EXE).
Stache firmware version 1.6 supports the BS2p, and also version 1.3x
of the IDE. Stache 1.7 adds support for the BS2pe (slower, low power
version of the BS2p) in IDE v1.33 and, we expect, for 2nd party
programs that use the tokenizer libraries and follow the published
programming protocols.
With version 1.2 to the current version 1.33 of the IDE, Parallax has
made major changes in the way that the IDE identifies Stamps that may
be attached to the com ports. The Stache has to be able to mimic any
of the Stamps. It has to deal with the timing and codes thrown at it
by the programming software, and then it has to turn around and
pretend to be a PC, so that it can identify and program any of the
available Stamp 2 models. We have been working closely with Parallax
to keep the Stache up with these changes.
-- regards,
Tracy Allen
mailto:tracy@e...
>Does it have the upgraded firware that allows it to work with the version
