Parallax-New BS2p40 Demo Board is in stock
BS2p40 Demo Board
#45186 $79.00
We are releasing a new demo board that was designed for the BS2p40 module, but
is also compatible
with all 24-pin BASIC Stamps. The demo board includes the following key
features:
- Standard 2.1 mm center-positive DC power jack
- DB9-F connector for serial programming
- On-board 5-volt regulator (LM2940 low-dropout)
- Large Solderless breadboard
- RJ-11 jack for Dallas/Maxim “Blue Dot Receptor” (DS1402D-DR8 / DS1402RP8)
sockets
- 14-pin IDC connector for parallel LCD (Parallax stocks a 2 x 16 LCD with cable
- #603-00006)
- Contrast potentiometer for LCD
- Selectable pull-up resistor for 1-Wire®bus (1 kW) and pull-down for LCD enable
pin (4.7 kW)
- Connections for P0 – P15, A0 – A15, Vin, Vdd, Vss and 1-Wire® connection
Read the complete documenation and learn more information here:
http://www.parallaxinc.com/html_files/products/BS_Boards/bs2p40_demoboard.asp
Erik Wood
Parallax
599 Menlo Dr. Suite #100
Rocklin, CA 95765
Sales: (888) 512-1024
Tech. Support: (916) 624-8333
Fax: (916) 624-8003
SumoBot............ www.parallaxinc.com
Education........... www.stampsinclass.com
Javelin Stamp...... www.javelinstamp.com
BS2p40 Demo Board
#45186 $79.00
is also compatible
features:
sockets
- #603-00006)
pin (4.7 kW)
Erik Wood
Parallax
Rocklin, CA 95765
Fax: (916) 624-8003
Can you elaborate on:
- RJ-11 jack for Dallas/Maxim "Blue Dot Receptor" (DS1402D-DR8 /
DS1402RP8)
sockets
Havent heard about this, what's it do?
Gary
--- In basicstamps@y..., "Erik Wood" <ewood@p...> wrote:
<snip>
I can. That's the port to which you, or any user, would physically
connect a blue-dot reader for iButtons. The iButtons contain almost
anything, including temp sensors. I personally advise you to go here,
www.maxim-ic.com and to the other site they will send you to, as well.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> From: gtdesrosi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=21SQIuj4uxTRBzmkAS2cqKklfN6g0dyhbx0Zou0_3mF2d7k1djMLMKzMkuiubXuFz5Km1ojjtEEEKc7O]gtdesrosi@c...[/url
> Sent: Monday, October 14, 2002 6:46 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Parallax-New BS2p40 Demo Board is in stock
> Erik,
> DS1402RP8)
> sockets
> Thanks
> Gary
> <snip>
> from the same email address that you subscribed. Text in the Subject
and Body of
> the message will be ignored.
Okay, maybe its just yet-another-1-wire-interface? (YAOWI).
I'm really trying to grasp this one...You have a blue dot sensor and
a probe. Touching the probe to the dot causes some 1-wire
transmission? How do you do things as mentioned such as temperature
sensors? Can you transfer data through the probe/dot connection?
I think I'm at a conceptual impass on this one.
Gary
--- In basicstamps@y..., "Gregg C Levine" <hansolofalcon@w...> wrote:
> Hello from Gregg C Levine
here,
well.
> > From: gtdesrosi [noparse][[/noparse]mailto:gtdesrosi@c...]
> > To: basicstamps@y...
stock
> > Erik,
> > DS1402RP8)
> > sockets
> > Thanks
> > Gary
> > <snip>
> > basicstamps-unsubscribe@y...
Subject
> and Body of
of a coiled cable. The cable connects to the BS2p demo boards through an
RJ-11 connector.
Check out this link for details:
http://www.ibutton.com/ibuttons/blue_dot.html
-- Jon Williams
In a message dated 10/14/02 5:48:06 PM Central Daylight Time,
gtdesrosi@c... writes:
> Erik,
> DS1402RP8)
> sockets
> Thanks
> Gary
dual iButton socket with an RJ-11 connection. The test program looked for a
device in the socket, then read the serial number from it. That code is
included in the documentation that comes with the BS2p40 Demo Board.
-- Jon Williams
-- Parallax
In a message dated 10/14/02 6:33:31 PM Central Daylight Time,
> Very odd. Now that I've read the datasheet, I'm even more confused.
security, similar to a card reader, only it is way more discrete.
iButtons look like watch batteries. When you place the iButton onto
an iButton connector that is connected to a device, the device
requests data to be transferred from the iButton to the device
through the connector. Does that make sense. They actually are
pretty neat little devices.
--- In basicstamps@y..., "gtdesrosi" <gtdesrosi@c...> wrote:
> Erik,
> DS1402RP8)
> sockets
> Thanks
> Gary
> <snip>
Yes, you can. The company, (Parallax has mountains of application notes
on that subject. Someplace anyway.
> From: gtdesrosi [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=JZNDKIPRfVeVY4HbqkRnPtbb87kGCSt3b7Nr4sNPyBTaWT9g_I1u85odQYgR1109oX4Gi-fnYaCbSw]gtdesrosi@c...[/url
> Sent: Monday, October 14, 2002 7:32 PM
> Gary
> here,
> well.
> stock
> > > Erik,
> > > DS1402RP8)
> > > sockets
> > > Thanks
> > > Gary
> > > <snip>
> Subject
> > and Body of
and Body of
