Can a single stamp BS2 module perform muliple tasks?
Greetings,
I'm new to the group and have read about the Stamp modules but never
used them. I've got an application that requires a controller that
can perform several tasks (measure temp and pressure, perform some
calculations on the data, feed the results to a display, save the
data and recall the data). I realize that I/O could be a limiting
factor but don't know if the Stamp can multitask. Does anyone have an
answer?
William
answer?
William
Multitasking is not a matter of the processor (in this case the PIC
microcontroller that the BS2 has inside). In fact, it's a matter of
software, all depends on your hability to program. Your desktop computer
processor (perhaps a P4 2GHz) it's not prepared to execute multiple tasks at
the same time. But your Operating System (i.e. Windows 2000) can do
something similar to a "multitask". How? For example:
You have three applications (Explorer, Word and Winamp), so the OS
execute a bit of code of the first app. then a bit of code of the second
app. and the a bit of code of the third app. then repeat this rutine, up to
one app doesn't something to do, so the SO doesn't use cycles of the CPU to
this app.
The key is time. It's like the cinema, if you see 15 pictures in a
second, you can think that what it's in the picture is moving. If you can
execute a piece of code of one app. in a short time, then a piece of code of
another app. in a short time, and repeat this rutine. You can think that
your Basic Stamp is doing multitasking.
This is just the base, then you have other modes of multitasking
more complicated. Microchip at their web site has some app. notes on
multitasking with PIC, take a look at that.
And of course you can make multitasking with your stamp, as I do
with my BS2.
Ezequiel Aceto,
Buenos Aires, Argentina
Sent: Monday, October 14, 2002 8:12 AM
Subject: SV: [noparse][[/noparse]basicstamps] Can a single stamp BS2 module perform muliple
tasks?
> Greetings!
> > answer?
> No, a BS2 can't multitask.
> That's not to say that it can't be used for whatever you want, though.
> You just have to be very careful about how you do it.
> (Short loops and stuff)
> Trygve
the time.
measure temp for example. temp is read from a remote device of some
sort. then fed back to the Stamp. the temp is an analogue signal so
it comes to an analogue to digital converter (ADC)
the ADC outputs a digital value.
the stamp reads the ditital value.
multipies
divides,
smooths
compares
reads another deivce, pressure ?
displays......
for avation, there are a few on here that take temperature and
pressure readings to determine density altitude of the model planes.
All you have to do is list your operations in a continuous string of
smaller operations so that the output of one can feed the next.
then groups of operations, say reading a pressure signal and scaling
it for something useful, THEN reading a temperature signal and
scaling IT to something useful, then combiing those answers to get a
value you want.
you can output any part to your display too, or have a button to
select what part you want to dispaly or change the display
periodically.
Realize that all mircroporcessors do not multi-task, but the time
slice between operations gets smaller with faster micros.
The term 'Real Time' is defined something like "faster than the
process requires" Temperature does not change fast, so reading it
every minute or so can be 'real time' pressure changes at the speed
of sound and electricity at the speed of light.
Hope that helps.
Dave
(stealth mode re-activated)
--- In basicstamps@y..., "Blue eyes" <wm_tell1@y...> wrote:
> Greetings,
never
an
> answer?
> William
I think you didn't understand me (Could it be because I don't speak
english frecuently). For example, supouse you comunicate with two devices,
one is serial RS232 and the other one is SPI. The SPI device send 32bits,
and the RS232 sends 2 bytes. supouse the serial RS232 device needs more
priority than the SPI. So you can make the communication with the SPI and
receive bit by bit, between each bit, you need to check if the RS232 device
needs "attention". If it needs attention, make a little stop in the SPI comm
and receive the 2 bytes from the RS232 device, when you received this two
bytes, you continue with you SPI communication. In a way it's multitasking
using IRQ (Interrupt Request). What do you think of multitasking? This is
the way your PC works, and you microcontroller is a little PC. There is no
processor that can do two task at the "same" time. And the conpect of
"PIPELINE" it's not true multitasking. If you want real multitasking at
hardware level you need two CPU. Eventhough one will be Master and the other
one Slave. But in Software, you make multitasking the way I show you. One
thing is to start a task, finish it and start another one. Another thing is
to start one task, start a second task and then distribute this two tasks in
processors cycles. The second one is multitasking, the first one it's what
you do every day. Perhaps you don't see it as multitasking because "the
Stamp is slow", but try to do something similar with you PC.
Ezequiel Aceto
Sent: Monday, October 14, 2002 10:37 AM
Subject: [noparse][[/noparse]basicstamps] Re: Can a single stamp BS2 module perform muliple
tasks?
> What you describe is not multi-tasking. it is just what we do all
> the time.
> multipies
> divides,
> smooths
> compares
> displays......
> value you want.
> periodically.
> Hope that helps.
> Dave
> > Greetings,
> never
> an
> > answer?
> > William
You are correct that a pipeline is a better term for how a processor
works, and that you need two processors to do real multi-tasking.
regarding the Stamp, there are no interupts on a Stamp. you might
need to find a different processor for that.
I would think that the SPI communication for a single task would only
take a few clock cycles and before and after a connection, you could
test to see if there is a serial request.
As you mentioned my desktop does only one process at a time, although
it does them really fast (compared to my old computer) that
it 'seems' like it is multi-tasking. Actually since I use Win-Doz it
doesn't seem like multi-tasking, but more like multi-waiting.
regarding speed, it is obvious that the faster the chip speed, the
less impact or slow down the wait would be between tasks.
If you attempted to add software interupts in a task, the speed would
drop considderably. I would think that there would be a better way
to do that.
Dave
--- In basicstamps@y..., "Ezequiel Leonardo Aceto" <Nik@i...> wrote:
> Hello,
don't speak
devices,
32bits,
more
SPI and
RS232 device
SPI comm
this two
multitasking
This is
There is no
of
multitasking at
the other
you. One
thing is
tasks in
it's what
because "the
> Ezequiel Aceto
> From: "Dave Mucha" <davemucha@j...>
> To: <basicstamps@y...>
muliple
> tasks?
> > the time.
some
signal so
> > multipies
> > divides,
> > smooths
> > compares
> > displays......
planes.
of
scaling
get a
> > value you want.
> > periodically.
speed
> > Hope that helps.
> > Dave
> > > Greetings,
> > never
that
some
the
limiting
have
> > an
> > > answer?
> > > William
> > basicstamps-unsubscribe@y...
Subject and
Eventhough the Stamp doesn't have an interrupt, you can
"simulate" one. Just include between each line of your code and IF..Then
structure asking for the state of a pin. It'll consume code, but you have a
kind of interrupt.
Ezequiel
Sent: Wednesday, October 16, 2002 9:54 AM
tasks?
> Hi Ezequiel,
> to do that.
> Dave
> > Hello,
> don't speak
> devices,
> 32bits,
> more
> SPI and
> RS232 device
> SPI comm
> this two
> multitasking
> This is
> There is no
> of
> multitasking at
> the other
> you. One
> thing is
> tasks in
> it's what
> because "the
> > Ezequiel Aceto
> muliple
> > tasks?
> > > the time.
> some
> signal so
> > > multipies
> > > divides,
> > > smooths
> > > compares
> > > displays......
> planes.
> of
> scaling
> get a
> > > value you want.
> > > periodically.
> speed
> > > Hope that helps.
> > > Dave
> > > > Greetings,
> > > never
> that
> some
> the
> limiting
> have
> > > an
> > > > answer?
> > > > William
> Subject and
support interrupts?
> Hello Dave,
IF..Then
you have a
> kind of interrupt.
> Ezequiel
muliple
> tasks?
> > Hi Ezequiel,
processor
only
could
although
Doz it
would
way
> > to do that.
> > Dave
wrote:
> > > Hello,
> > don't speak
two
> > devices,
send
> > 32bits,
needs
> > more
the
> > SPI and
> > RS232 device
the
> > SPI comm
> > this two
> > multitasking
multitasking?
> > This is
> > There is no
conpect
> > of
> > multitasking at
and
> > the other
> > you. One
Another
> > thing is
two
> > tasks in
> > it's what
> > because "the
> > > Ezequiel Aceto
> > muliple
> > > tasks?
do all
> > > > the time.
of
> > some
> > signal so
> > > > multipies
> > > > divides,
> > > > smooths
> > > > compares
> > > > displays......
> > planes.
string
> > of
next.
> > scaling
> > get a
> > > > value you want.
to
> > > > periodically.
time
the
reading it
> > speed
> > > > Hope that helps.
> > > > Dave
> > > > > Greetings,
but
> > > > never
controller
> > that
perform
> > some
save
> > the
> > limiting
anyone
> > have
> > > > an
> > > > > answer?
> > > > > William
> > Subject and
Subject and
interrupts, yet can be very useful if applied properly.
-- Jon Williams
-- Parallax
In a message dated 10/16/02 12:51:52 PM Central Daylight Time,
ghidera2000@y... writes:
> I dont remember offhand which one it is, but doesn't the 2p or the sx
interrupt, of sorts, that you can use sort of creatively.
On Wed, 16 Oct 2002, Ezequiel Leonardo Aceto wrote:
> Hello Dave,
> kind of interrupt.
> Ezequiel
> tasks?
> > Hi Ezequiel,
> > to do that.
> > Dave
> > > Hello,
> > don't speak
> > devices,
> > 32bits,
> > more
> > SPI and
> > RS232 device
> > SPI comm
> > this two
> > multitasking
> > This is
> > There is no
> > of
> > multitasking at
> > the other
> > you. One
> > thing is
> > tasks in
> > it's what
> > because "the
> > > Ezequiel Aceto
> > muliple
> > > tasks?
> > > > the time.
> > some
> > signal so
> > > > multipies
> > > > divides,
> > > > smooths
> > > > compares
> > > > displays......
> > planes.
> > of
> > scaling
> > get a
> > > > value you want.
> > > > periodically.
> > speed
> > > > Hope that helps.
> > > > Dave
> > > > > Greetings,
> > > > never
> > that
> > some
> > the
> > limiting
> > have
> > > > an
> > > > > answer?
> > > > > William
> > Subject and
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
... And would that be used in conjunction with a startup routine??
I dont suppose that a startup routine would realize the different reasons a
reset had occurred, would it?
James
On Thu, 17 Oct 2002 12:21:24 -0700 (PDT) "Sean T. Lamont .lost."
<lamont@a...> wrote:
> It sort of has one interrupt ; you can trip the
> reset line. That's an
> creatively.
> wrote:
> > Hello Dave,
> > kind of interrupt.
> > Ezequiel
> > From: "Dave Mucha"
> > To:
> > tasks?
> > > Hi Ezequiel,
> that.
> old computer) that
> like multi-waiting.
> between tasks.
> > > to do that.
> > > Dave
> Aceto" wrote:
> > > > Hello,
> > > don't speak
> > > devices,
> > > 32bits,
> > > more
> > > SPI and
> > > RS232 device
> > > SPI comm
> > > this two
> > > multitasking
> > > This is
> > > There is no
> > > of
> you want real
> > > multitasking at
> > > the other
> > > you. One
> > > thing is
> > > tasks in
> > > it's what
> it as multitasking
> > > because "the
> > > > Ezequiel Aceto
> > > > From: "Dave Mucha"
> > > > To:
> > > muliple
> > > > tasks?
> > > > > the time.
> > > some
> temp is an analogue
> > > signal so
> converter (ADC)
> > > > > multipies
> > > > > divides,
> > > > > smooths
> > > > > compares
> > > > > displays......
> > > planes.
> > > of
> > > scaling
> > > get a
> > > > > value you want.
> change the display
> > > > > periodically.
> with faster micros.
> > > speed
> of light.
> > > > > Hope that helps.
> > > > > Dave
> wrote:
> > > > > > Greetings,
> > > > > never
> > > that
> > > some
> > > the
> that I/O could be a
> > > limiting
> > > have
> > > > > an
> > > > > > answer?
> > > > > > William
> > > Subject and
> subscribed. Text in the Subject and Body of
> email: lamont@a...
> - Miles Davis
cause a "hard" reset and the Stamp would completely reinitialize. As soon as
the Stamp went into Reset, the pin would release and the initialization
process would take place.
-- Jon Williams
-- Parallax
In a message dated 10/18/02 11:32:59 AM Central Daylight Time,
jamesrwaldron@e... writes:
> Along this line, what is the best way to programmatically trip a Stamp reset?
> startup routine??
Let's not forget that when you perform a RESET, you
lose your variables and I/O pin configuration/states.
Knight Designs
324 West Main Street
Montour Falls, NY 14865
(607) 535-6777
http://www.knightdesigns.com
__________________________________________________
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
but you could tie it to an external event, like a button press or
something. If you tied the button to both reset and p0, you'd know on
startup whether to process button-related code.
> James
> > creatively.
> > wrote:
> > > Hello Dave,
> > > kind of interrupt.
> > > Ezequiel
> > > From: "Dave Mucha"
> > > To:
> > > tasks?
> > > > Hi Ezequiel,
> > that.
> > old computer) that
> > like multi-waiting.
> > between tasks.
> > > > to do that.
> > > > Dave
> > Aceto" wrote:
> > > > > Hello,
> > > > don't speak
> > > > devices,
> > > > 32bits,
> > > > more
> > > > SPI and
> > > > RS232 device
> > > > SPI comm
> > > > this two
> > > > multitasking
> > > > This is
> > > > There is no
> > > > of
> > you want real
> > > > multitasking at
> > > > the other
> > > > you. One
> > > > thing is
> > > > tasks in
> > > > it's what
> > it as multitasking
> > > > because "the
> > > > > Ezequiel Aceto
> > > > > From: "Dave Mucha"
> > > > > To:
> > > > muliple
> > > > > tasks?
> > > > > > the time.
> > > > some
> > temp is an analogue
> > > > signal so
> > converter (ADC)
> > > > > > multipies
> > > > > > divides,
> > > > > > smooths
> > > > > > compares
> > > > > > displays......
> > > > planes.
> > > > of
> > > > scaling
> > > > get a
> > > > > > value you want.
> > change the display
> > > > > > periodically.
> > with faster micros.
> > > > speed
> > of light.
> > > > > > Hope that helps.
> > > > > > Dave
> > wrote:
> > > > > > > Greetings,
> > > > > > never
> > > > that
> > > > some
> > > > the
> > that I/O could be a
> > > > limiting
> > > > have
> > > > > > an
> > > > > > > answer?
> > > > > > > William
> > > > Subject and
> > email: lamont@a...
> > - Miles Davis
On Fri, 18 Oct 2002, Chris Savage wrote:
> --- James Waldron <jamesrwaldron@e...>
> > startup routine??
> Chris Savage
> Knight Designs
> (607) 535-6777
> Do you Yahoo!?
