74ls166
Unfortunately I've not been able to find any of the parallel to
serial chips (in stock) mentioned in any of the appnotes or websites
I've checked. I do have a few PCF8574As on order (two weeks away).
In the meantime I found a chip, the 74LS166 that does parallel to
serial but my (fumbling) attempts at using it are going nowhere. I
can't seem to find an example of the chip in use on any sites.
Anyone have a link to one?
Here's a PDF link http://www.fairchildsemi.com/ds/DM/DM74LS166.pdf
I thought to try it like an SPI chip, using shiftin to read it. Not
sure if this is even appropriate.
Here's what I thought was the most likely setup.
Pin 1 (Serial in) to P10 on the stamp as Data_in
Pin 7 (Clock) to P9 on the stamp as Clock
Pin 15 (shift load) to P8 on the stamp as latch
P2-5 -> switches -> 10k resistors -> +5v
P6 (Clock inhibit) ground
P8 (ground) ground
P9 (clear) ground
P10-12 (inputs) ground
P13 (output) open
P14 (input) ground
P16 +5v
Hard to figure out these chips. Datasheets for similar chips from
the same manufacturer all use different terms for the same pin
functions etc...
P8 (ground) ground
P9 (clear) ground
P13 (output) open
P14 (input) ground
P16 +5v
functions etc...
