freezer temp warning
After my large freezer died last night, I want to make a temp sensor
that will beep or flash a light when the temperature rises above 20
or 30 degrees. I need to know what sensors will work, where to get
them, and some help coding (its been awhile since I played with my
basic stamp...) I have a basic stamp 2, but I think thats kind of
over kill just for a temp sensor, so I might get a basic stamp 1 to
do this.
Tad Heckaman
do this.
Tad Heckaman
tad@h... writes:
> do this.
Good morning Tad
An Lm34DZ hooked up to an ADC will will do the job nicely. I use the
TLC2543, an 11-channel 12-bit ADC. Overkill probably, but it seems to be
chaper than a 4-channel ADC. If I can help with the code let me know.
Sid Weaver
W4EKQ
Port Richey, FL
easy code, have your alarm system up and going in an hour or so. You can
purchase the DS1620 from Parallax.
-- Jon Williams
-- Parallax
In a message dated 10/11/02 10:28:40 AM Central Daylight Time,
tad@h... writes:
> do this.
they would work better, since they have wires on them, not a single
chip. The freezer would have alot of water and condensation, so I
would think a chip would rust and fail after a few weeks. Would those
other ones be just as easy to hook up? Or I could put my whole
project inside a waterproof box and freeze the whole thing, but I
dont know if the basicstamp would work at -20 degrees.
--- In basicstamps@y..., jonwms@a... wrote:
> You could connect a DS1620 directly to the BASIC Stamp and with
some really
You can
> -- Jon Williams
> -- Parallax
> tad@h... writes:
sensor
20
get
my
to
> > do this.
just for the job.
--- In basicstamps@y..., goflo@p... wrote:
> I've done a similar thing with a water heater using a thermistor
> & capacitor as described in the BS1 apps - Beeps a piezo at desired
> temp.
> If the controller is'nt in the freezer you'll find the set point
> drifts quite a bit with variation in ambient temp - If this is'nt
> acceptable another sensor can sense ambient so the pgm can compute
> a suitable offset, or you could do something sneaky like measure
> the cycle time of the AC line and compare the measurement with the
> actual time.
> regards, Jack
> p.s. - Mouser, Digikey, Jameco, & a BS1 is plenty.
STAMP to do this at all. Just get a temp sensor like the LM34
(available at parallax) and a comparitor like the LM339 quad
comparitor. Hook up the sensor to the comparitor, adjust it to the
correct voltage and connect the output to a light and you are done.
It will cost you about 10 dollars or less.
And, if you wanted to do something fancy you could take all four
comparitors in the LM339 package and create a 4 LED bar graph (maybe
three yellow and one red). And, hook up some sort of alarm on the
red one.
STAMP's are great but many times we use them as a crutch when it is
not necessary.
sensor
> do this.
> Tad Heckaman
chip... and its cheap!
--- In basicstamps@y..., "dirt939" <stamp@d...> wrote:
> I know this is a BASIC STAMP message board but I would not use a
(maybe
> red one.
> not necessary.
> sensor
20
get
my
to
> > do this.
> > Tad Heckaman
need a heat sink? [noparse];)[/noparse] but I am not quite to the point of making my own
basic stamp... even though I am thinking of making my own robot with
a laptop as its controller...
> Or buy the interpreter chip from Parallax & roll your own.
> Cheap & lets you diddle the clock to suit the app.
> Or, if you've got one of the old Parallax 16CXX pgmrs, stuff
> the interpreter & pgm into a 16C58 - Mo' cheapa yet, plus
> there are 40 MHz '58s these days, if you need a screaming BS1 [noparse]:)[/noparse]
> regards, Jack
> tadheckaman wrote:
> > This sounds like a good idea too, I would be willing to buy a BS1
> > just for the job.
desired
> > > temp.
is'nt
compute
the
> > > actual time.
> > > regards, Jack
temp.
actual time.
regards, Jack
the LM34
https://www.jameco.com/cgi-bin/ncommerce3/ProductDisplay?
prmenbr=91&prrfnbr=2802&cgrfnbr=501&ctgys=
and the LM339
prmenbr=91&prrfnbr=353083&cgrfnbr=501&ctgys=
Would this need any special resisters and capasitors, or is there a
scematic or this somewhere that I could look it up.
(maybe
> red one.
> not necessary.
> sensor
20
get
my
to
> > do this.
> > Tad Heckaman
regards, Jack
> just for the job.
> > temp.
> > actual time.
> > regards, Jack
main thing is they have a very thin cable that does not allow the door
gasket on the freezer to leak.
> do this.
and very accurate. Once you have it programmed as a standalone
thermostat using your BASIC Stamp II, you can attach three wires to
the outside, and coat the whole thing heavily in plastic dip or wax
to protect it from the humidity. Bring three wires out of the
freezer, +power, common and output.
|--> freezer
+2.7-5.5v
8| |
output
7|Thi |
common
4| |
| .1uf | 1620 |
p8-p4 `
The output terminal cannot drive any kind of heavy load by itself.
It might need an extra transistor to drive your alarm.
-- Tracy
>Thanks I found it on the website.. But I see 2 others that look like
>some really
>You can
>> -- Jon Williams
>> -- Parallax
>> tad@h... writes:
>sensor
>20
>get
>my
>to
> > > do this.
stand-alone mode as well.
> > do this.
Unless you're itchin' to make this a stamp project, try http://alarms.4mg.com/
or to roll your own or get some circuit ideas, try
http://alfaie.virtualave.net/electronics/circuits/protections/p3.html
http://www.epemag.com/0502p1.htm
>some really
>You can
> > -- Jon Williams
> > -- Parallax
> > tad@h... writes:
>sensor
>20
>get
>my
>to
> > > do this.
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________
Mike Walsh
walsh@i...
programming, alarm and power connections and pooky the rest with hot glue.
> gee, never heard of overclocking a basic stamp before... would it
Not if it's in the freezer [noparse]:)[/noparse]
jack
overclocking as well.
--- In basicstamps@y..., Mike Walsh <walsh@c...> wrote:
> Tad,
> Mike
like
those
> >some really
> >You can
> > > -- Jon Williams
> > > -- Parallax
> > > tad@h... writes:
> >sensor
above
> >20
> >get
with
> >my
kind of
stamp 1
> >to
> > > > do this.
> > basicstamps-unsubscribe@y...
Subject and
> Mike Walsh
> walsh@i...
the tempco of the Stamp is enough to do what you want.
I like dirts' solution, though - Too easy.
have fun, Jack
doing it...
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> The nice thing about the DS1620 is that it is a single chip
solution
> |--> freezer
> +2.7-5.5v
8| |
> output
7|Thi |
> common
4| |
> | .1uf | 1620 |
> p8-p4 `
> -- Tracy
like
those
> >some really
> >You can
> >> -- Jon Williams
> >> -- Parallax
> >> tad@h... writes:
> >sensor
above
> >20
> >get
> >my
of
1
> >to
> > > > do this.
tad@h... writes:
Tad, if you use the LM34, always put a 1.2K resistor in series with the
sensing lead and a .1uf bypass to ground on the pin the LM connects to.
Sid Weaver
W4EKQ
Port Richey, FL
--- In basicstamps@y..., Newzed@a... wrote:
> In a message dated 10/11/2002 13:11:39 Eastern Daylight Time,
> tad@h... writes:
a
the
to.
> Sid Weaver
> W4EKQ
> Port Richey, FL
The same
smartdim@a... writes:
> Right on,,,,,the stamp is over kill. More power to "us" electronics guys.
Not if you want a "smart" device that is easy to reprogram....
custom applications using the stamp.
The stamp would perform the task easily.
The freezer alarm does not need reprogramming however. It is a one time set
up. All am saying is the stamp is overkill. The same end result can be
accomplished with considerably less $$$$$
