Can anyone recommend an I2C parallel to serial chip?
Archiver
I want to try making a keyboard out of pushbuttons (matrix type).
But I can't seem to find an I2C chip to do this. Basically the
opposite of a shift register.
I have seen the PCF8574A but that requires an extra latch line to
toggle it over to inputs. I can use it no sweat if needed. Just
seeing how pin-economic I can be.
data lines). When you do a device read, it will tell you what it "sees" on
its pins. To be accurate, it is a shift register and each read is internally
buffered. To get the current state of the pins, do two reads and use the
second.
-- Jon Williams
-- Parallax
In a message dated 10/10/02 10:41:29 AM Central Daylight Time,
ghidera2000@y... writes:
