I''m a dope! LM044L datasheet
I found the problem, it was a wayward quote... Ended up with extra
spaces at the end of a string which were printing right where that
number was supposed to be. It'd erase the old numbers then the
numbers were drawn again - thus the strobing.
But thanks for the hints and the links - printed out the stuff this
time and stuffed them into my binder of datasheets - the one that is
growing at an altogether alarming rate.
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> One thing to remember is you don't blank and rewrite the whole
display. You
> should reposition the cursor and rewrite only the characters that
change.
> This will keep the flashing to a minimum.
> You may also need to update the LCD at a lower rate -- maybe once
per second
> or slower.
display. You
change.
per second
> or slower.
