Help my modem is saying
Hello fellow basic stamp friends,
I have contected a BS2 to a external modem but, my terminal program( Hyper
terminal Private Edition)
Keeps saying "RING","RING","RING" after connection with the remote (in this
case the BS2).
I can send data over and over but the terminal program keeps saying
"RING","RING","RING".
How can I stop this? ? ?
Thanks in advance.
Emile Tempelaars.
Netherlands
case the BS2).
Thanks in advance.
Emile Tempelaars.
Netherlands
different ways of turning off the caller ID function depending on
the modem. I do this with the command AT#CID=0
--- In basicstamps@y..., "Emile Tempelaars" <e.tempelaars@p...>
( Hyper
(in this
> case the BS2).
> Thanks in advance.
> Emile Tempelaars.
> Netherlands
give when it detects a ring voltage on the line to indicate an incoming
call. It can be verbose in this case or a number if verbose is turned
off. Check your manual. This is elementary for ALL modems.
gtdesrosi wrote:
> RING is what the modem says when a caller ID is detected. Theres
> ( Hyper
> (in this
> > case the BS2).
> > Thanks in advance.
> > Emile Tempelaars.
> > Netherlands
modem, then wait for the modem to send CONNECT to the stamp, then you can
send your data, theres more to it though, you gotta hang up, check for no
carrier etc etc.
Chris
Sent: Thursday, October 10, 2002 3:03 AM
Subject: [noparse][[/noparse]basicstamps] Help my modem is saying "RING"
this
> case the BS2).
> Thanks in advance.
> Emile Tempelaars.
> Netherlands
I seem to recall seeing an article on the subject of having a Stamp send
data into a modem. The whole thing was on the website for an Australian
based firm which sold Basic Stamps, and a few other micros. And they
even sold parts to US customers, which is why I know about them. I
haven't bought anything from them, but there's always a first time.
You'd have to hit the Parallax site for it, but I think it was
www.dontronix.com but I could be wrong.
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
(This company dedicates this E-Mail to General Obi-Wan Kenobi )
(This company dedicates this E-Mail to Master Yoda )
> From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BQxPKiaQ3jXVaf8qPZldijQNSGmDDm7_qoLvCeabdmMGB_erPAdag2DyswW80fubtzqeniZ7-sJPd5sY]fuel@b...[/url
> Sent: Wednesday, October 09, 2002 6:45 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Help my modem is saying "RING"
> after you get RING RING and the stamp sees it, you must send ATA to
the
can
no
> carrier etc etc.
> Chris
> From: "Emile Tempelaars" <e.tempelaars@p...>
Hyper
(in
> this
> > case the BS2).
> > Thanks in advance.
> > Emile Tempelaars.
> > Netherlands
Subject and
and Body of
http://docs.yahoo.com/info/terms/>
call comes in. One of the S registers (I forget which one) sets the number
of rings before it answers.
> "RING" has nothing to do with callerid. It is the response all modems
> > ( Hyper
> > (in this
> > > case the BS2).
>after you get RING RING and the stamp sees it, you must send ATA to the
>carrier etc etc.
There should be no "RING RING" seen by the Stamp. I can see checking the
CD (carrier detect) line to determine if the modem is connected, but all
that other stuff should be handled transparently by the modems if they're
configured properly. I'd set the modems so they do NOT give progress
messages or codes and just check the status of the CD line to know it was
OK to send data, or that anything incoming is useful data vs unnecessary
progress messages. You can do it either way, but why load down the Stamp
with handling what the modem should do transparently?
Jim H
>You have to issue an ATA command to get the modem to pick up the line when a
It would be a very old and very dumb modem that requires an ATA command to
answer, but anything is possible.
On anything but a really dumb, old modem, you can set S0=2 to set the modem
to answer automatically on the second ring - which allows any other devices
that might be on the line (or the modem itself if it's that smart) to
capture Caller-ID info that comes at the tail of the first ring.
I guess what we really need here is to know what sort of modem this guy
has. It has to be really (really, really) old if it's so dumb that it
needs manual commands like ATA to answer a call. It's important to know
because I'd sure not want to unnecessarily burden the Stamp with chores the
modem can do itself, with the Stamp just watching the CD line to know
whether the modem is connected or not.
Jim H
That is S0. S0=0 turns off autoanswer. S0=1 makes it answer after
one ring, and so on.
ATH1 puts the modem offhook. ATH0 or ATH puts it on hook (hangs up).
>case the BS2).
What is connected to what? This is the scenario I imagine:
phone line
Hyperterminal<--->local modem<
>remote modem<--->BS2
Or, could it be?
phone line
Hyperterminal<--->Stamp<--->local modem<
>remote modem<--->???
It helps to supply more information!
Is this "RING" message appearing on your hyperterminal screen? Most
likely, as others have suggested, something is not configured for
autoanswer. Another remote possibility is that you are seeing
"reverberation" of the ring message, if the modem happens to be
connected to Stamp port P16.
-- Tracy
I agree, even after my previous answer saying to issue an ATA to answer. The
reason I am stuck with watching the strings the modem sends is that I am out
of io lines. Now I simply set it to auto answer and wait for "CONNECT" to
then send data. I havent played with modems for a while, but hell they are
getting messy to deal with.
I have purchased a netcom modem today, which does not recognisee the ATA
command anyway, but they still set the auto answer to off as default. I'm
starting to think that really understanding modems is becoming a whole trade
in itself.
Chris
Sent: Thursday, October 10, 2002 7:54 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Help my modem is saying "RING"
when a
number
modem
devices
the
> Jim H
> > > ( Hyper
> > > (in this
> > > > case the BS2).
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"Do not fear mistakes, There Are None" - Miles Davis
> >carrier etc etc.
> Jim H
manually picks up the line and ATS0=x sets it to auto answer if x > 0. In
any case if you wanted to monitor the modem for caller ID data and whatnot
and let the software decide if / when to pick up the line, ATA would work.
Somewhere I have some stuff on caller ID data and the various things that
are sent and what they mean. If I run across it I'll post it.
> Ats0=X. And you only have to send ata if ats0=0.
when a
number
your brain. [noparse]:)[/noparse]
On Thu, 10 Oct 2002, Rodent wrote:
> Thats the ticket -- its been too long since I had to mess with a modem. ATA
> when a
> number
>Hey Jim...
>in itself.
Yeah, once modems got really fast and fancy a few years back they added
features right and left and many mfgrs didn't always use the same
AT-strings to set the parameters. With most modems you can hook the modem
up to your PC via Hyperterminal and, using the modem manual, set the values
you want and then store those values so they'll remain set even after power
is switched off and back on. Some even store the number to dial. That
would remove any requirement for the Stamp to set up the modem, but without
a spare pin to monitor the CD line you're still stuck with your present
approach to detecting a completed connection. You could set a delay after
initiating a connection and then assume you were connected, simplifying
things a bit, but you could easily find the Stamp sending data to a
connection that failed. All in all it looks to me like you're already
making the best of your situation. Continued good luck with it.
BTW, did you ever mention your application? If not I'm interested in
hearing and probably others also.
Jim H
I use the stamp for measuring fluid delivered, then store in separate
Eeprom. Then connect to stamp with vb6 application to download the data into
a spreadsheet. I have a few systems out there using GSM (digital) mobile
phone modems and they work very well, but this new netcomm modem is giving
me the %&$##. I also use dallas memory keys for downloading data, we have
around 100 systems out there using memory keys for data transfer when the
office is close to the fluid measurement system. Have just completed
multiple measurement systems using rs485 network, it goes well and can
monitor up to 8 systems simultaneously.
I am having all sorts of fun with this netcom modem, as I now have it
connecting ok and downloading data, but for some reason it adds / corrupts
data at the same points in each download. I must have some sort of
compression or error checking on or something.. I'll get there soon.
Regards.
Chris Anderson
Sent: Friday, October 11, 2002 6:48 AM
> At 07:15 10/10/02, Chris Anderson wrote:
> >Hey Jim...
The
out
are
ATA
trade
> >in itself.
values
power
without
> Jim H
>I think this is toggled by atq0 / atq1, in standard configs.
That turns off/on the result codes like "RING" and "CONNECT." I have no
idea why the modem keeps saying "RING" after it's connected, but it strikes
me he may needs to deal with the cause, because if he just turns off result
codes to hide it he won't know when he's connected unless he has a spare
Stamp pin to monitor the state of the modem's CD line. But it's worth trying.
I got email from him - Emile Tempelaars, The Netherlands,
<e.tempelaars@p...>.
He has a new V.92 capable TRUST 56K fax/data/modem. His Hyperterminal
screen says "CONNECT 115200" and after that it shows RING RING RING. He
can send data to the Stamp, but can't read anything back because all he
sees is RING RING RING. Maybe that added info will allow someone to help
him better. I'm afraid I don't have a clue why this is happening and my
remarks below were a result of misunderstanding his problem earlier.
Jim Higgins
> > >carrier etc etc.
> > Jim H
The string for disabling MNP compression and error checking is usually,
AT \N0 %C0 ^M
The difficulty in my experience turns up when two modems are
negotiating a connection--A vintage modem will fail to connect at all
with an MNP modem. Or if they do connect, all you will see is
garbage, or nothing at all.
-- Tracy
>Jim..
>Regards.
>Chris Anderson
>From: "Jim Higgins" <HigginsJ@s...>
>> >Hey Jim...
>The
>out
>are
>ATA
>trade
>> >in itself.
>values
>power
>without
>> Jim H
>Subject and Body of the message will be ignored.
