Modems...
Does anybody know any good sites with some basic modem theory. I hava stamp
sending data thru a modem, but am having trouble receiving (its not a speed
issue). I think the modems at each end are incompatible due to settings
internally that I can change, but dont know how to.
Thanks in advance...
Chris
Chris
Documentation Project). Its mostly about Linux, but a lot of other good
info seems to find its way there as well.
Blake
> Chris
her book "Serial Port Complete."
Dennis
From: Chris Anderson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iKgx_gKiwUaliqfaqpk9ofvWjWD0oUu4bu-DpWUxxfTq-_CFbvYPxYKc0913Q3ATuaZ-BZD2fubwy2vqrQ]fuel@b...[/url
Sent: Wednesday, October 09, 2002 4:56 AM
To: Stamp Group
Subject: [noparse][[/noparse]basicstamps] Modems...
stamp sending data thru a modem, but am having trouble receiving (its
not a speed issue). I think the modems at each end are incompatible due
to settings internally that I can change, but dont know how to.
Chris
>Chris
There is some information on my site:
http://www.emesys.com/BS2rs232.htm#modem
Also, here is a nice article by Scott Edwards from Nuts & Volts:
ftp://nutsvolts.com/stampaps/st_ap24.pdf
Also look in the Cermetek literature, app. notes, especially the one
on the AT commands and S registers:
http://www.cermetek.com/04/app.html
It always helps immensely to have the technical manual for the modem
you are using, because there is a lot of variation among modem models
in which commands and registers are implemented in order to support
their features.
Quite often a simple old modem will have trouble talking to a modern
advanced modem, unless you turn off advanced MNP and fax features
like compression and correction. The AT command for that is usually
AT \N0 %C0 ^M
The articles above have a lot of detail and special considerations
for the Stamp. What do you mean when you say "trouble receiving"
(its not a speed issue)?
-- Tracy
