Just when I thought I had I2c sussed 24LC16WPI
I have this EEPROM hooked up and working fine, its not a
troubleshooting thing [noparse]:D[/noparse]
Anyway, I thought I2C required that you set each chip's address by
grounding or pulling high the three address pins. THe 24LC16
doesn't! I've been searching the net for the last couple of hours
(including the yahoo group archive) and I can't seem to find
anything about this.
If I stuck two of these chips onto the I2C bus, just how would I
differentiate between them? Or is it assumed that if you're cheap
arsed enough to buy just the 16k version then you won't have more
than one memory chip ? 8o\
So far this is the only question I have about I2C. Got multiple SPI
chips working yesterday and today I'm trying I2C. In a month or so I
might actually start something useful.
Your assumption is correct, only one of these on a bus at a time. The
address pins are no connects.
Steve
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
can only connect one device to your bus. You should probably download the
specs (do a search [noparse][[/noparse]google] for 24LC16.PDF).
The three "address" bits in the control byte actually select the one of eight
256 byte blocks within the device. The address within the block is the next
byte in the sequence.
If you want to use multiple devices, consider the 24LC32.
-- Jon Williams
-- Parallax
In a message dated 10/8/02 8:35:25 PM Central Daylight Time,
ghidera2000@y... writes:
For once, I actually DID understand the data sheet then. I couldn't
see how this chip could co-exist on the bus so I though I wasn't
understanding the spec. I was wrong because I was right!
Oh well, it'll still work fine for one of the projects I have in
mind. Need it just for logging temperatures and storing strings for
an LCD menu system.
GLOAT: Got myself some 4x20 LCDs for $18 cdn apiece! Now I need more
eeprom space to store strings [noparse]:D[/noparse]
That's exactly what I'm doing with my datalogger project too. :-)
Saved almost 20% stamp EEPROM by putting all display messages and Menu's in
a 24C02 i2c eeprom (rather than, for example, startscreenmessage data
"Hello", put the string "Hello" in to external memory...).
Ben.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: "ghidera2000" <ghidera2000@y...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Wed, 09 Oct 2002 03:08:26 -0000
> Subject: [noparse][[/noparse]basicstamps] Re: Just when I thought I had I2c sussed 24LC16WPI
> Ah ok thanks for the replies!
> an LCD menu system.
