I2C, see if I actually understand it.
So the I2C spec allows me to interface with (compliant) chips using
three stamp pins. Once the first device is on the I2C bus, subsequent
devices only require a single pin (Chip Select) more. The other two
pins are shared between all I2C devices.
So if I had say.. 8 DS1620 chips. I would need 10 pins to control
them all. 3 for the first chip and one each for the next 7 (seperate
CS).
To increase the number of inputs, I could use a shift register. Each
shift register output pin would go to the CS pin of (up to) 8 other
I2C compatible devices, all of which would share the clock and data
lines (although some chips may have a seperate clock source, like a
crystal). So for my 8 DS1620s, I'd only need three pins of the stamp.
Is the above correct?
CS).
count the power and ground connections.
Parallax says the I2C protocol requires only two I/O pins, serial data and
serial clock, and they may be shared with other devices.
> CS).
Vdd through 1K - 4.7K). This differs from SP1/3-wire used by the DS1620
because the chip selection is carried in the protocol as part of the command
byte sent down the bus.
So, if you have eight DS1721s, you can connect to all of them through just
two Stamp pins since they use the I2C protocol. If you're using a BS2p, you
can use I2CIN and I2COUT. If you're using any other Stamp, you'll have to do
the I2C comm in code. It's not hard.
You would, in fact, need 10 pins for eight DS1620s. You would need two for
clock and data, then one for each chip select (called Reset on the DS1620).
Another thing you need to do is connect each DS1620 to the common bus through
a 1K resistor. This will prevent shorts in case two or more devices get
activated at the same time.
Yes, you could reduce the pins by using an output shift register like the
74HC595. The x595 could share your clock and data lines, but would need its
own Latch line. The x595 outputs would connect to the DS1620 Reset pins.
This would bring your total pin count down to three: clock, data, 74x595
Latch. Of course, you also need the x595, and the resistors.
Just to be clear, the DS1620 does not use the I2C protocol. The DS1721 does.
-- Jon Williams
-- Parallax
In a message dated 10/7/02 1:43:51 PM Central Daylight Time,
ghidera2000@y... writes:
> CS).
One thing I've definately learned, the choices are bewildering...
I2C, SPI, that RS-435 (455? arg, the 1000+ ft 2 wire IC network). And
thats just the ones I've seen in my short two weeks.
I guess which one I choose will have more to do with what my local
suppliers carry than capabilities of the spec.
--- In basicstamps@y..., Rodent <daweasel@s...> wrote:
> I was thinking SPI was the 3-wire and I2C was 2-wire. Keep in mind
you don't
with?
Nick
on 7/10/02 6:36 PM, ghidera2000 at ghidera2000@y... wrote:
> Ah ok, right operation, wrong spec [noparse]:D[/noparse] I'm getting it slowly!
> you don't
> of the message will be ignored.
Nuts & Volts of Basic Stamps books. Its probably also in various Stampworks
and Stamps in Class documents as well. Just download from the Parallax
website and browse at your convenience.
> Im curious which of these standards the Shiftin/Shiftout commands comply
> > you don't
they can be used (a bit of a cheat) with I2C as well. I say it's a "cheat"
because SHIFTOUT drives the data line high and low; in the I2C spec, the
master only pulls the clock and data lines low and lets the bus pull-ups take
them high. If you're concerned about a bus short, you can insert a 220
resistor in your clock and data lines. It's pretty cheap insurance for your
BASIC Stamp.
There is I2C code for non-BS2 Stamps posted on our web site (associated with
my Nuts & Volts column).
-- Jon Williams
-- Parallax
In a message dated 10/7/02 6:29:52 PM Central Daylight Time,
nickstedman@s... writes:
> with?
> Nick
> with?
Both. Although, with I2C, there are other overheads.
Jon Williams did an article on I2C not long ago, and I also have some
examples on my site:
http://www.lennard.net.nz/ click on circuit ideas then I2C (under buses).
The BS2p also has I2C commands built in (I2Cin, I2Cout), but if you don't
have a BS2p, then Shiftin/out will work.
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: Nick Stedman <nickstedman@s...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Mon, 07 Oct 2002 19:31:57 -0400
> To: <basicstamps@yahoogroups.com>
> Subject: Re: [noparse][[/noparse]basicstamps] Re: I2C, see if I actually understand it.
> with?
> Nick
>> you don't
>> Body
