reward
Archiver
we're getting desperate...willing to offer $$ for an
hour of someone's time.
need help with programming the BS2 for a school project...
__________________________________________________
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
Do you Yahoo!?
Actually make that a lot more.
Not looking for your dollars but will try to help if I can.
I'm new to the BS2 but an old geiser to programming.
*********** REPLY SEPARATOR ***********
Mike B.
Sent: Sunday, October 06, 2002 4:01 AM
Subject: [noparse][[/noparse]basicstamps] reward
> Do you Yahoo!?
heres a brief description of my project:
i have 3 inputs and 3 outputs.
in4, in5, in6 are inputs and out 13, out14, out15 are
outputs.
pin4 is an incrementing button.
pin5 is a decrementing button.
pin6 is connected to a sensor.
out13,out14,out15 will go to a decoder.
im trying to give the outputs to send logic highs in
binary sequence.
for example:
out13 out14 out15
0 0 0
0 1 0
0 1 1
1 0 0
1 0 1
1 1 0
1 1 1
at normal condition, the inputs are all = 000
and the outputs will be 000 also til a change in the
inputs.
if pin4 or pin6 goes to a logic high, i want the
outputs to increment 1 step and stay there til the
next logic high is sensed.
if pin5 goes high, i want the outputs to decrement 1
step and stay there til the next logic 1 is sensed.
hope that makes sense. the output will be connected
to a 3-8 decoder to control an amplifier. but all i
need the stamp to do is just to sense a change and to
give the proper outputs. please help???
Do you Yahoo!?
Here's a way to do it with a 5 line state machine:
x var nib ' counts up or down from 1 to 8
s0 var nib ' prior state
s1 var nib ' present state
sx var nib ' change in state
loop:
s1=inB ' reads inputs p4, p5, p6 all at once
sx=s1^s0&s1 ' detects change 0->1 in any bit
s0=s1 ' update old state
x=x+sx.bit0+sx.bit2-sx.bit1 max 8 min 1 ' increment and decrement
outD=x-1<<1 ' transfer state %000->%111 to outputs p13,p14,p15
debug bin3 s1,tab,bin3 sx,tab,bin3 outD ' show internal states
goto loop
What's the reward? That took 10 minutes, so $$/6?
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>thanx for replying. im using the BS2 OEM.
>outputs.
>binary sequence.
>for example:
>out13 out14 out15
> 0 0 0
> 0 1 0
> 0 1 1
> 1 0 0
> 1 0 1
> 1 1 0
> 1 1 1
>inputs.
know how much you've helped me. now, i just have to
finish the hardware and its done. i can finally
graduate. just tell me what you need and i'll
accomidate. thanks again!
--- Tracy Allen <tracy@e...> wrote:
> Hi Gordon,
> loop:
> outputs p13,p14,p15
> internal states
> goto loop
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> an
> project...
> are
> >outputs.
> in
> >binary sequence.
> >for example:
> >out13 out14 out15
> > 0 0 0
> > 0 1 0
> > 0 1 1
> > 1 0 0
> > 1 0 1
> > 1 1 0
> > 1 1 1
> the
> >inputs.
> 1
> connected
> i
> to
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
