suggestions? please help?
i made 3 of the outputs of the stamp to make LEDs
light up in binary from ooo to 111 incrementing and
decrementing.
my question is how do make count in steps depending on
3 inputs (2 are buttons). if any of 2 of the buttons
are pressed and shows an active high, i want the LEDS
to increment from 001 to 010 only. if the buttons are
pushed again then it will go up again from 010 to 011
and stay until another change from the input is made.
any suggestion?
__________________________________________________
Do you Yahoo!?
Faith Hill - Exclusive Performances, Videos & More
http://faith.yahoo.com
decrementing.
any suggestion?
Do you Yahoo!?
pressed and then add or subtract the pin from the count. You may need to
program in a delay as well, but it does work.
Did this on a BS1 recently for a project to test / adjust servos. The
buttons change the pulse length going to the servos. This is an example of
how to do it.
Cnt = Cnt + PIN1
Cnt = Cnt - PIN2
> decrementing.
> any suggestion?
heres my sample program that i'm using for my school
project. i'm a rookie at using the basic stamp so i
appreciate any advice. thanks again. to give a brief
description of my project:
-my 3 inputs will be all active lows when normal
condition and so would be the output pins
-my 3 outputs will be connected to a 3to8
decoder...i've reading example source codes and it's
almost the same as using a stepper motor as far as the
outputs are concern but all of the examples are in
sequence. i mean that it different from what i need.
i know how to make an led to do sequence but i dont
know how to make it on command (stop and go)
-the 3 outputs are stable when its 000 and its max 111
-when the inputs detects a high, i want the output to
go up 1 and stay there until the next logic 1.
problem:
-i've gotten my output to count.
-i'm lost as far as getting it to increment and have
it stay there until the next condition.
-i've tried BUTTONS and BRANCH commands and it didn't
work because i couldn't get it to stay at a stage. the
whole program would restart.
-the biggest problem is my lack of understanding of
the pbasic language...i admitted!
thanks once again!
Do you Yahoo!?
