Not Stamp Related, but I know you guys can answer this!
Archiver
Sorry for using this forum for a non-STAMP related question, but I
know that you can help! I just got a new laptop from work (an IMB
Tinkpad T23). I want to keep the AC Power Adapter at work and have
one at home. I have an old AC Power Adapter from a Thinkpad that I
had a few years ago. They look similar, but not identical. The plug
that fits in the computer is the same as the new one. On the old AC
Adapter, the specs are Output of 16 volts at 3.36 amps. The new AC
adapter that came with the new laptop indicates 16 volts at 4.5 amps.
Do you think it is o.k. to use the AC Adapter that is rated 1.14 amps
lower than the one supplied?
Thanks for your help on this one... see, I told you you guys would be
able to answer this for me!
Steve
Steve
>On the old AC Adapter, the specs are Output of 16 volts at 3.36 amps.
>The new AC adapter that came with the new laptop indicates 16 volts at
>4.5 amps.
Probably NOT a good idea. My guess, based upon similar units that I have
seen, is that these power supplies are switch mode units that have hard
limits somewhat above the nameplate rating. A further guess is that the
newer laptop has a better (larger, newer) battery than the old laptop and
that it can be charged at a higher rate than the old one.
The charging circuitry in the laptop is going to assume that it can charge
at the maximum design rate, which the old power supply cannot handle. This
will most likely cause problems.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
provide enough current for some or all of it's circuitry...
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: "sjoblin001" <steven_joblin@h...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sat, 05 Oct 2002 12:21:23 -0000
> Subject: [noparse][[/noparse]basicstamps] Not Stamp Related, but I know you guys can answer this!
> Steve
> of the message will be ignored.
it could still be useful.
Check the power draw. it may be that some add-on features, CD or
somehting made the higher powe supply necessary.
Dave
--- In basicstamps@y..., Ben <ben@l...> wrote:
> The newer laptop requires extra current, so the old one will not be
able to
> Electronics R&D
> Hm: +64 4 972 7567
> Mb: +64 21 536 627
> 87 Spencer Street
> Crofton Downs
> Wellington
> New Zealand
glass is
to be."
the
of you
that
backwards.
> > Reply-To: basicstamps@y...
answer this!
have
I
plug
AC
AC
amps.
amps
would be
> > Steve
> > basicstamps-unsubscribe@y...
Subject and Body
