Stamp to internet through PHP?
I have Al Williams book and it talks about accessing the stamp
through web pages. This is cool and all but, I'd rather stay away
from VB/VC. I do have (and love) PHP, which I use for online
database stuff. Does anyone know where I can find information about
how to access the serial port though PHP (under windows)? Checked
the PHP manual and searched the web but couldn't find anything about
it - if its even possible...
and numbers over time using a RS232 connection. Simply send XML encoded
data out the serial port once per second. Frontier Data System software
can capture the data, store it into a database, then search the data to
deliver dynamic reports to your browser.
Uses Linux, Apache, MySQL and PHP to provide a 100% open source solution.
The XML RS232 output looks something like this. The idea is to hard code
the XML tags and have the data values as variables.
*<w,0,2>552</w,0,2><w,0,1>37846</w,0,1><w,0,0>32771</w,0,0><n,0,0>3200</n,0,0><n\
,0,1>502</n,0,1>$
The string is sent to the client PC once per second. When the string
changes records are created.
Encoding Scheme
*<Data Type,Station,Element>Value</Data Type,Station,Element>$
Data Types
b - Bit bit using 0 or 1
w - Word encodes 16 bits using integer values between 0 and 65535
n - Number Number (float)
Station
0 to 255
Element
Bit 0 to 240
Word 0 to 15
Number 0 to 255
Value
Bit 0 to 1
Word 0 to 65535
Number -3.4E+38 to 3.4E+38
For the rest of the description check out the online tutorials at
frontietech.ca.
www.frontiertech.ca
Free Open Source Software for Data Aquisition and Data Mining.
have to write a program in VB/VC and call that.
Brian G.
> From my understanding of php, it is a scripting language only.
You will
> Brian G.
Actually its a lot more than that. Its pretty well a full blown
language.
Anyway, I found what I was looking for in the annotated docs.
// Use this code to write directly to the COM1 serial port
// First, you want to set the mode of the port. You need to set
// it only once; it will remain the same until you reboot.
// Note: the backticks on the following line will execute the
// DOS 'mode' command from within PHP
`mode com1: BAUD=9600 PARITY=N data=8 stop=1 xon=off`;
$fp = fopen ("COM1:", "w+");
if (!$fp) {
echo "Uh-oh. Port not opened.";
} else {
$e = chr(27);
$string = $e . "A" . $e . "H300";
$string .= $e . "V100" . $e . "XL1SATO";
$string .= $e . "Q1" . $e . "Z";
echo $string;
fputs ($fp, $string );
fclose ($fp);
Its a lot simpler than I was thinking which is probably why I didn't
spot it the first time around [noparse]:D[/noparse]
Windows):
1) Use the COM functions to talk to a COM control like MSCOMM32. There
should be some others out there (see http://www.lvr.com).
2) Use Java. PHP integrates with Java nicely
(http://www.php.net/manual/en/ref.java.php).
3) Use fopen() to open serial port.
4) use dio_open (assuming dio is enabled).
5) Use a serial proxy: http://www.lspace.nildram.co.uk/freeware.html and
http://www.trios.org/php/serialport/.
6) Use Netporter (http://www.al-williams.com/netporter.htm) to handle
all the communications and generate web pages. You could put it on an
odd port number and have PHP read the generated pages, modify them, and
serve them. There are lots of examples around on how to read a Web page
from PHP and a nice class at:
http://lwest.free.fr/doc/php/lib/index.php3?page=net_http_client&lang=en
As you can tell, I like PHP too....
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: ghidera2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xefYX5ET_v2A4oB-3dDv6PsTJKN8YakmzqKB4ngrKxeeDmxb_GeNoNHYMRwS0HFmmtM5TlADmXf_OdfklPHxYg]ghidera2000@y...[/url
> Sent: Friday, October 04, 2002 4:45 PM
> Subject: [noparse][[/noparse]JUNK] [noparse][[/noparse]basicstamps] Stamp to internet through PHP?
Your book is *BAD* for me... Way too many cool things in there! Just
had to go out and buy an LCD (LM044L), wasn't planning on it but
after reading the LCD section of your book, I just *had* to have
one.
You're a cruel, cruel man Mr. Williams [noparse]:D[/noparse]
P.S. I'm constructing a mental block, willfully ignoring the fact
that there is a robot section in the book. Wonder how long I can
hold out...
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> There are several ways you could go (all assuming you are running
PHP on
> Windows):
There
handle
an
them, and
page
> Al Williams
> AWC
lower
time....
Cruelly,
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> one.
> hold out...
