Problems with drive a 12V DC relay with stamp and switching transistor
Archiver
I'm using 12 volt power supply that is powering my stamp 2 and also
powering a 12 volt relay.
I am using a standard NPN switching transistor(sorry don't have the
specs on it here). I have it set up so the +12v passes through the
solenoid of the relay first then to the collector on the transistor
and finally to ground. When 5 volts (via series resistor) is sent to
the base of the transistor the relay turns on fine with no problems.
This is on a breadboard.
When this circuit is hooked up to the stamp and I send a high signal
through one of the pins. The solenoid turns on but then after a
second or two clicks off momentarily, and continues to do this.
I've monitored the current and normally when the solenoid is active
I'm drawing about 100mA. But when the solenoid clicks off
momentarily, I see the current dip just a little. Also, if I remove
the solenoid and place a resistor in place. I still see the little
dip in current at regular intervals.
Is there something wrong with hooking up the stamp and solenoid to
the same power supply or perhaps with the transistor?
Thanks for any suggestions.
other words your code probably sets the pin high and then ends -- so when
the Stamp reaches the end of your code and runs out of things to do, it goes
to sleep and all the output pins blip every 2 seconds or so. Put this
statement at the end of your code:
END: GOTO END
This will keep the Stamp running and the relay should stay closed.
You most definitely want to use a diode in reverse bias across
your relay and/or your transistor. I would suggest both.
Also you should use a resistor between the BASE of the transistor
and the Stamp I/O. In order to keep the current from the STAMP I/O
20mA or less you need to at least use a 220 Ohm or higher resistor
value.
Note: Use 1.2 instead of .6 if you are using a Darlington transistor
V_I/O = 5V from Stamp
( V_I/O - .6V ) / 20mA = 220 Ohms = R_BASE
To determine if your transistor is adequate, measure the resistance
of your relay coil (out of circuit) to determine the amount current
the relay should demand at 12V
I = (V_source -.6) / Coil_resistance
i.e.
I = (12V - .6) / 50 Ohms
I = 11.4V / 50 Ohms
I = 228 mA = Coil_Current
In this case, your transistor should be rated to dissipate 137mW
(P = I*V = 228mA * .6) and have a hfe rating of at least 12. Divide
Coil_Current by BASE_Current (228mA / 20mA = 11.4). Both of these
values are pretty small.... Typically you would see a hfe of 50 to
several thousand... in which case lower your BASE_Current to a more
suitable level. The Idea is, is that you want to saturate your
transistor as much as possible,
o--->|---o
R_BASE C
o--COIL--o-->+12V
I/O >----/\/\--o
B |
| E--o o---|<---o
o--/\/\--o
o-->GND
100K
>Hi,
Beau Schwabe Mask Designer II - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
