Using Mosfet to drive solenoid...
Archiver
Greetings,
I would like to know if anyone has experience using mosfets to drive
large current loads. What I would like to do is to use the logic
level output of the stamp to drive an optoisolator and then have the
output of the opto drive the gate of the mosfet.
The mosfet would then engage the solenoid on the starter motor of a
small gasoline engine. The mosfet is rated at 15 amps and typically
the solenoid draws only 2-3 amps. I would be using separate power
supplies as well, eliminating having to tie the grounds together.
I also would like to drive an electric clutch directly from the
mosfet. The clutch draws 7 amps and I would have thermal & fuse
protection in case of a stall. The clutch would be engaged sometimes
for up to an hour- will this reduce the life of the mosfet? I have
this problem worked out using mosfets to drive on board relays, but I
would like to go all solid state.
Thanks in advance,
Tim
Thanks in advance,
Tim
could I find an electric clutch for a gas engine? I have an upcoming
project that may require one.
Rich
From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xKMnuzBD7ymDPT63ONMrim2pVX_yrw5OVG9ZTV4ZUvipzPHaYeNdoJZzPXI1rcwnBDRSDjS8ZrnIElcqWI0]tweaver@i...[/url
Sent: Thursday, October 03, 2002 9:06 AM
Subject: [noparse][[/noparse]basicstamps] Using Mosfet to drive solenoid...
Greetings,
Thanks in advance,
Tim
Your use of Yahoo! Groups is subject to
stamp. Handles about 9 amps.I use them a lot and they are good for driving 12
volt loads from the stamp.
http://www.irf.com/product-info/datasheets/data/irl520.pdf
Sent: Thursday, October 03, 2002 7:06 AM
Greetings,
Thanks in advance,
Tim
from the same email address that you subscribed. Text in the Subject and Body
clutches that handle similar power levels and
duty cycles.
rehards, Jack
Richard Brull wrote:
> I know it's off the subject, but you mentioned an electric clutch. Where
