RS232 Interface (the end of this thread...)
And the answer is... SEROUT!
Set up the interface, config the UART to 38400,8,1,O then start
chatting with the Sony VCR through the remote control box I just
created!!
Thanks again, Tracy!
Jim
--- In basicstamps@y..., "Jim Cambron" <nehsoft@h...> wrote:
> As per usual, DUHHH!
> I took a quick look at the Stamp Manual V2.0 and the 3100 data
sheet
> but could not find info on SPI/Microwire interfacing.
> I think I remember somewhere in previous research that a Stamp can
> interface using SPI/Microwire (or maybe not...) Any idea where I
> might find that info? I shall continue the search from this end...
> Even if the Stamp is not microwire compatible, I bet that there is
a
> suitable UART with a parallel input interface that can do the job
> (although I may run low on I/O pins)!
> Thanks, Tracy!
> Jim
> --- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> > >3) This is the tough one...
> > >Sony uses the baudrate of 38400,1 stop and odd parity to
> communicate
> > >with most of their commercial broadcast equipment (in my case, a
> Sony
> > >portable Beta VCR). Your baudrate may be different... not
enough
> > >information provided by you...
> > >The problem I have is the odd parity. Which brings me to my
> question:
> > >What can you all suggest about getting around this by simulating
> odd
> > >parity at 38400 on a BS2?
> > >Jim "Ack" Cambron
> > How many data bits? If 7 + odd parity, you can select 8 data
bits
> > and fill in the 8th bit with your own parity calc. If 8 + odd
> > parity, then I'm afraid you will have to tack on an external
UART,
> > like the MAX3100.
> > -- Tracy
created!!
Jim
sheet
a
> Thanks, Tracy!
> Jim
> communicate
> Sony
enough
> question:
> odd
> > >Jim "Ack" Cambron
bits
UART,
> > like the MAX3100.
> > -- Tracy
>created!!
>Jim
Well, SHIFTOUT, not SEROUT.
I have some demo Stamp code for the MAX3100 posted at this URL:
http://www.emesys.com/BS2IrDA.htm
It talks specifically about the IrDA capabilities of the chip, but
with a simple change of the configuration register, it works
hardwired.
Change the configuration word to, say, $E04D, instead of $C08D. Thas
sets wired connection (instead of IrDA), 2 stop bits (instead of 1)
and 8-byte FIFO enabled. Oh, that is 2400 baud. But you can figure
it out.
You do need inverters for standard RS232, or, I think the MAX3110 has
RS232 inverter/drivers built in.
-- Tracy
Sent: Wednesday, October 02, 2002 2:31 PM
Subject: [noparse][[/noparse]basicstamps] Re: RS232 Interface (the end of this thread...)
> >created!!
> >Jim
> hardwired.
> it out.
> -- Tracy
