Multiple button depresses...
Archiver
Greetings,
Trying to create a menu system ala HP laser printer- select
categories with one button, use two others to change up or down.
There are approximately 7-8 parameters that need to be monitored and
adjusted.
On the other hand, the hardware is not built yet, is this something
that might be better hardwired via buttons- one per Stamp i/o pin? If
so, can you press (for example)the button connected to P3, hold it
and then also press P5/P6 to raise/lower the value?
I need to still have a good deal of room for code, as well.
Really just grasping here...Any help is appreciated
Tim
adjusted.
Tim
cool ones for $25-30. Turn the knob to scroll through the menu and press
down on it to select. The coolness factor is much higher than three buttons.
This would take 3 pins as well.
> adjusted.
many inputs as you want.
From: ohiotim2 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z4tEHpyYeNwdujAbNBe53VNY1U1gT782Jy4im7sl-p9DA4qhmGJ349-JXjMAEunGNeg699VgDbsJGQdzujBfIQ]tweaver@i...[/url
Sent: Tuesday, October 01, 2002 11:27 AM
Subject: [noparse][[/noparse]basicstamps] Multiple button depresses...
Greetings,
adjusted.
Tim
