Maximum I/O Pin voltage?
Archiver
I know this must be in the Stamp Manual somewhere, I have looked up other
electrical specs before...but I can't find it now!
What is the maximum input voltage to an I/O Pin?
Thanks in advance,
Neil
Thanks in advance,
Neil
Allowable range is 0V thru 5V. Hard limits that still allow valid
operation are -0.3 thru +5.3V. Letting out smoke limits are voltages less
than -0.6V or greater than +5.6V.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
>Thanks in advance,
>Neil
Technically the protection diodes won't let you take the I/O's above 5.6V
with a 5V source
without passing current through the protection diodes, which by the way are
not meant to
handle excessive currents, so it is best to keep your input voltages at or
below 5V.
Protection Diodes:
VDD >
|<----o----|<
<VSS
I/O
I'm not sure about the newer BS2's, but with the original BS2, it actually has
a PIC16C57C-20/SS. Looking at the specs for the PIC16C5X on page 25 you can
see the "equivalent circuit for a single I/O pin"... not shown are the
protection
diodes that go to VDD and VSS. Look at page 61 for electrical specifications.
http://www.microchip.ru/cdrom/download/lit/pline/picmicro/families/16c5x/devices\
/16c57c/30453c.pdf
Beau Schwabe Mask Designer II - ATL
National Semiconductor Enterprise Networking Business Unit
500 Pinnacle Court, Suite 525 Wired Communications Division
Mail Stop GA1 Norcross, GA 30071
