solution for fast transients
Hi folks!
I did a project here using pic16c63 to outdoor use, connected to low
voltage power lines. Very similar to watthour meter. I use a
transformless power supply.
Well....
I started some tests according IEC 61000 (fast transients) and,
amazing!, the registers values CHANGE with 2kV/4kV fast transients
apllied... I have a time counter and the output time changes showing
me that the time counter register varies. I have a LCD display and it
starts blinking during fast transients apllied.
Anyone has some advice to solve this?
Well....
remote monitoring systems for power grids (1 phase, 3 phase), so no doubt
have to deal with such things as 2kV/4kV fast transients.
http://www.metering.co.nz/
cheers,
Ben.
> From: "trader2mil" <trader2000@i...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Mon, 30 Sep 2002 14:22:50 -0000
> Subject: [noparse][[/noparse]basicstamps] solution for fast transients
> Hi folks!
> Well....
> of the message will be ignored.
always used traditional transformer supplies plus optical isolation (which I
know doesn't really apply in this case) and conventional snubbing. I have
put together my own method of determining snubber component values that has
recently saved a project that's connected to 480V lines. mail me off-list
since it's not really on topic here - and please be patient while I am
swamped with work. I am however glad to share this info.
Chris
> Well....
do you fail at. I suspect your power supply is coupling the noise to
your micro. Are your digital lines sandwiched between power/gnd
planes? I would add ferrite beads or T filters to all of your dc
supplies on your board. You need to select a bead/T filter that is
rated to handle the current. Murata and Stewart are 2 sources that
come to mind. Do you have a power inlet filter to filter noise out at
the source? Do you have problems with radiated suseptability and
radiated emmissions?
Jason
--- In basicstamps@y..., "trader2mil" <trader2000@i...> wrote:
> Hi folks!
low
> Well....
showing
it
and it is coupled phase, neutral, load and ground. All 4 coupling was fail
with 2 and 4 kV.
Yesterday , I used a line filter and passed the 2kV, all coupling methods,
but not 4kV. Today I will use a Schaffner line filter (better).
My circuit board is one face only. I do not use a transformer power supply.
It is transformerless.
denis
Sent: Tuesday, October 01, 2002 3:16 PM
Subject: [noparse][[/noparse]basicstamps] Re: solution for fast transients
> To what level are you testing to under IEC 61000. What coupling modes
> Jason
> > Hi folks!
> low
> > Well....
> showing
> it
