Help wanted. How can I change variables with switches?
Hello.
Help wanted.
I am a newcomer.
Please show me anybody how I can change variables with switches.
Like this:
a var byte
a = 1
How I can change the variable a with a switch? (from 1 to 10)
I have tried this with subroutines but maybe know anybody another way?
Therefore:
switch one on a = 1
switch two on a = 5
switch three on a = 10
This is a little bit code with the variable:
FOR level = 0 TO 255 Step a 'a is the variable I will change
PWM Pin1,level,25
gosub delay
NEXT
Best regards, Kai
Help wanted.
I am a newcomer.
Like this:
a var byte
a = 1
Therefore:
switch one on a = 1
switch two on a = 5
PWM Pin1,level,25
gosub delay
NEXT
Best regards, Kai
hope I'm right)
By using either the inL for inputs 0 to 7 or inH for inputs 8 to
15 you can read a 8 bits or a byte of data which is arranged by
pins 7 6 5 4 3 2 1 0
128 64 32
16 8 4 2 1
so if pins ( or switches in you case ) 1,3,5 are on you have
2+8+32 or 42 with this you can get all numbers from 0 to 255
Larry Gaminde
Sent: September 25, 2002 10:50 PM
Subject: [noparse][[/noparse]basicstamps] Help wanted. How can I change variables
with switches?
Hello.
Help wanted.
I am a newcomer.
Like this:
a var byte
a = 1
way?
Therefore:
switch one on a = 1
switch two on a = 5
PWM Pin1,level,25
gosub delay
NEXT
Best regards, Kai
from the same email address that you subscribed. Text in the
Subject and Body of the message will be ignored.
Your use of Yahoo! Groups is subject to
