serial com
how do I turn off the full duplex mode when using a
stamp BS2 with a MS PC basic program? It gets
annoying re-hitting keys because of the echo . . . is
there a trick around this at both ends? Thanks . . .
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
Do you Yahoo!?
causes the echo -- there is no way to turn it off. You can use standard pins
(P0 - P15) for SERIN and you won't get the echo.
If you *need* to use the programming port, your PC program can filter out the
echos since it knows that anything sent will be kicked back.
-- Jon Williams
-- Parallax
In a message dated 9/25/02 8:48:13 AM Central Daylight Time,
jrem123@y... writes:
My Toshiba Laptop Dose filter the echo but my PC will not filter the echo
I ave checked the system setting they are both set the same the LT works hte
PC does not.
Regards Larry
I'm a student in computer science,(I doesn't speak english very well,
sorry), I would like to create a program to
communicate with my basic stamp 2e by serial port. But, there is a
problem, if I start my program, the basic stamp stop.
This is my program :
// Compiled with DJGPP
#include <stdio.h>
#include <conio.h>
#include <pc.h> // if you use borland, replace this line
// by #include <dos.h>
#define COM1 0x03F8
#define COM2 0x02F8
#define COM3 0x03E8
#define COM4 0x02E8
#define COMx COM1
#define TxD COMx
#define RxD COMx
#define DLLB COMx
#define IER (COMx + 1)
#define DLHB (COMx + 1)
#define IIR (COMx + 2)
#define FCR (COMx + 2)
#define LCR (COMx + 3)
#define MCR (COMx + 4)
#define LSR (COMx + 5)
#define MSR (COMx + 6)
void Init_COMx(void)
outportb(LCR , 0x80);
outportb(DLLB , 0x0C); // 9600 bauds
outportb(DLHB , 0x00);
outportb(LCR , 0x03); // 1 bit stop
char Recept_car(void)
while((inportb(LSR) & 0x01) != 0x01);
return(inportb(RxD));
int main(void)
char Reception;
Init_COMx();
Reception = (char)0;
while(Reception != 27)
Reception = Recept_car();
if (Reception != 0)
printf("%c\n", Reception);
else
printf("_RIEN_\n");
return 0;
and this my program on my basic stamp :
'{$STAMP BS2e}
' EMISSION / RECEPTION
Rx con 8
Tx con 9
TxFlow con 10
N9600 con $40F0
' ROBOT BUG
valeur var byte
valeur = 65
Main:
serout 16, N9600, [noparse][[/noparse]valeur]
pause 100
goto Main
The basic programm send the caractere "A" and my program on the PC
recept the caractere and show it on the screen, but it doesn't work !!
please, help me....
or with a jumper. You can also put a capacitor in series with DTR (ATN
on the Stamp) as shown in the Stamp manual. This prevents the PC from
resetting the Stamp with a steady signal, but still allows the reset
pulse used by the programmer to pass.
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: megakyle2003 <hchris@v...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aJxkISdNkRHqizC5OnQ-DH96xxfRDnoCjvEWXyLHIsWzx4OAjpeDpW9eOM8BSWWkrAXOnDdCWLU7]hchris@v...[/url
> Sent: Friday, February 21, 2003 9:52 AM
> Subject: [noparse][[/noparse]basicstamps] serial com
> hello,
> #include <stdio.h>
> #include <conio.h>
> #define COM1 0x03F8
> #define COM2 0x02F8
> #define COM3 0x03E8
> #define COM4 0x02E8
> #define COMx COM1
> #define TxD COMx
> #define RxD COMx
> #define DLLB COMx
> int main(void)
> char Reception;
> Init_COMx();
> if (Reception != 0)
> else
> printf("_RIEN_\n");
> return 0;
> '{$STAMP BS2e}
> Rx con 8
> Tx con 9
> TxFlow con 10
> N9600 con $40F0
> ' ROBOT BUG
> valeur var byte
> valeur = 65
> Main:
> pause 100
> goto Main
> the PC recept the caractere and show it on the screen, but it
> doesn't work !!
> please, help me....
> from the same email address that you subscribed. Text in the
from within your program. That's how I do a lot of my PC<->Stamp
communications.
Looks like you want add something like this in your Init_COMx
procedure:
outportb(MCR , inportb(MCR) & 0xFE); // deassert DTR
Setting DTR (the low order bit of the modem control register) will
hold your Stamp in reset, so you want to clear it and keep it that
way throughout your program. Then your hard-wired programming cable
will work fine for programming and communication.
Also, to specify 9600 inverted on your BS2e, use baud value 16468 or
$4054 rather than $40F0.
Steve
