Control of small DC motor
Archiver
Hello-
I'm working on a project for a retail store. They have a need for a ceiling
mounted motor that rotates a sign or graphic hanging off of it. The tricky part
is that they want the ability to vary the speed and direction of the rotation of
this motor. Changing the speed and direction manually by way of switch and
potentiometer mounted on the motor is completely fine. The motor I'm thinking
of using is a 1.5-3 VDC gearmotor. I know that I can easily change the direction
of the motor by just reversing the polarity of the wires going to the motor
with a switch. The hard part for me is coming up with the best way to vary the
speed of the motor.
I thought about using a Motor Mind B motor controller from Solutions Cubed
connected to a BS1 or BS2 for control. Is this the best way or is there a
simpler solution?
Does anyone out there have any experience with this, advice, or suggestions?
Thank you in advance,
Deneb
speed of the motor.
simpler solution?
Deneb
>Hello-
>ceiling mounted motor that rotates a sign or graphic hanging off of it.
>The tricky part is that they want the ability to vary the speed and
>direction of the rotation of this motor. Changing the speed and direction
>manually by way of switch and potentiometer mounted on the motor is
>completely fine. The motor I'm thinking of using is a 1.5-3 VDC gearmotor.
>I know that I can easily change the direction of the motor by just
>reversing the polarity of the wires going to the motor with a switch. The
>hard part for me is coming up with the best way to vary the speed of the motor.
>Cubed connected to a BS1 or BS2 for control. Is this the best way or is
>there a simpler solution?
>Deneb
Deneb -
Just a word of caution. Many gearmotors are NOT REVERSIBLE. Make sure that
the motor you use clearly states that it IS reversible. Otherwise, no
amount of circuity is going to overcome jammed gears.
If you find that the Motor Mind B doesn't have the current capacity to meet
your requirements I believe there is now a Motor Mind C with higher capacity.
Check the Solutions Cubed web site for more information:
http://www.solutions-cubed.com/
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks for the good advice. I will make sure that the motor I use is designed to
be reversed.
As for the current of the motor, I think I'm fine with the motor Mond B. Do you
have any experinece interfacing it with the BS1 or BS2?
Thanks, Deneb
> From: Bruce Bates
> Reply To: basicstamps@yahoogroups.com
> Sent: Tuesday, September 24, 2002 9:15 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Control of small DC motor
> At 08:55 AM 9/24/2002 -0700, you wrote:
> >Hello-
motor.
> >Deneb
> Deneb -
> Regards,
> Bruce Bates
>Bruce-
>designed to be reversed.
>Do you have any experinece interfacing it with the BS1 or BS2?
>Thanks, Deneb
Deneb -
There are examples and sample code on the Solutions Cubed web site I believe.
Bruce
> > From: Bruce Bates
> > >Hello-
> gearmotor.
> The
> the motor.
> suggestions?
> > >Deneb
> > Deneb -
> capacity.
> > Regards,
> > Bruce Bates
> and Body of the message will be ignored.
while so i would have to go back and look at the code
for specifics, but the jist of it is all you have to
do is serially throw 2 byte hex codes at it. The MMB
onboard controller then translates your instructions
to the motor output(speed, direction, tachometer,
brake, etc.). couldnt be easier. their site has
sample code for basically all of the motor functions
for BS1 & BS2. link found here:
http://www.solutions-cubed.com/Products/MotorMindB/motormindB_download.htm
hope that helps you out.
ross
--- "Irvin, Deneb" <irvin@d...>
wrote:
> Bruce-
> the motor I use is designed to be reversed.
> with the motor Mond B. Do you have any experinece
> Thanks, Deneb
> > From: Bruce Bates
> motor
> > >Hello-
> have a need for a
> vary the speed and
> the motor by just
> > >Deneb
> > Deneb -
> gears.
> information:
> > Regards,
> > Bruce Bates
> Text in the Subject and Body of the message will be
> ignored.
> ignored.
__________________________________________________
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com
between the stamp and the motor and sent a variable PWM signal could be used
to control the motor speed.
>From: "Irvin, Deneb" <irvin@d...>
>Reply-To: basicstamps@yahoogroups.com
>To: "Basicstamp group" <basicstamps@yahoogroups.com>
>Subject: [noparse][[/noparse]basicstamps] Control of small DC motor
>Date: Tue, 24 Sep 2002 08:55:30 -0700
>Hello-
>part is that they want the ability to vary the speed and direction of the
>rotation of this motor. Changing the speed and direction manually by way of
>switch and potentiometer mounted on the motor is completely fine. The
>motor I'm thinking of using is a 1.5-3 VDC gearmotor. I know that I can
>easily change the direction of the motor by just reversing the polarity of
>the wires going to the motor with a switch. The hard part for me is coming
>simpler solution?
>suggestions?
>Deneb
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
Thanks for the help. I have two questions for you, if you don't mind. First, is
it necessary for the motor that I want to use to have a tach back to the MMB?
Secondly, how can I manually (potentiometer or other analog device) tell the
stamp how fast the motor should be going so that it can then tell the MMB to
either slow down or speed up the motor?
PL - I ask this second question of you also. If I run PWM to a mosfet to
control the speed of the motor, how do I tell the stamp how fast to drive the
mosfet and motor? Do you have any resources (schematics, code , app notes ) for
this solution. I have an idea of how it should be wired, but I sure could use
some help.
Thanks to both of you for your help on this. I really do appreciate it!
Regards, Deneb
> From: Klutch
> Sent: Wednesday, September 25, 2002 2:25 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Control of small DC motor
> interface is a snap, i havent played with it for a
> ross
> wrote:
> > Bruce-
> > Thanks, Deneb
> > > From: Bruce Bates
> > motor
> > > >Hello-
> > have a need for a
> > vary the speed and
> > the motor by just
> > > >Deneb
> > > Deneb -
> > gears.
> > information:
> > > Regards,
> > > Bruce Bates
> > ignored.
> > ignored.
> Do you Yahoo!?
back to use the MMB. basically it is just to let you
know that what the RPM is and to give feedback to the
BS if the load changed, so that the BS knows to
command it to speed up. there is a constant speed
command (SPDCON) which should maintain a desired speed
automatically without your direct intervention. it is
all on the datasheet.
taken from the data sheet:
"Optional tachometer input reads 0-65,535Hz"
"Features include the ability to read a motor’s
tachometer frequency, automated speed control, 254
discrete steps of speed control, and motor direction
changes."
"Also included are gate time selections for the
tachometer and automated speed control mode, a
pulse counting function, and the STATUS command.
The Motor Mind B comes complete with a watchdog
timer to eliminate the possibility of a system
firmware
failure."
for your second question their are probably many
different methods that you could use. off the top of
my head, you could run the pot into an ADC, and then
into the BS, go to a lookup table, and then feed that
speed to the MMB. as stated above, the MMB only
allows 254 discrete speed steps, so regardless of your
continually variable input, there are still only a
finte number of motor outputs (way more than enough
for your task i wager).
there are all sorts of ADC samples available on the
web, that coupled with the code provided by solutions
cubed, and id pretty well say your jobs done!!!!!
(BTW, i believe that this could easily be done with
the BS1 if this is the only task it is to perform.)
ross
wrote:
> Ross-
> if you don't mind. First, is it necessary for the
> MMB? Secondly, how can I manually (potentiometer or
> other analog device) tell the stamp how fast the
> MMB to either slow down or speed up the motor?
> run PWM to a mosfet to control the speed of the
> (schematics, code , app notes ) for this solution. I
> could use some help.
> Regards, Deneb
> > From: Klutch
> motor
> code
> to
> MMB
> instructions
> functions
> > ross
> > wrote:
> > > Bruce-
> that
> fine
> experinece
> > > Thanks, Deneb
> > > > From: Bruce Bates
> DC
> > > motor
> > > > >Hello-
> They
> > > have a need for a
> to
> > > vary the speed and
> Changing
> using
> of
> > > the motor by just
> the
> way
> Is
> with
> > > > >Deneb
> > > > Deneb -
> NOT
> > > gears.
> the
> Motor
> > > information:
> > > > Regards,
> > > > Bruce Bates
> subscribed.
> subscribed.
> be
> > > ignored.
> be
> > > ignored.
> > Do you Yahoo!?
> ignored.
=== message truncated ===
Do you Yahoo!?
