High Voltage, Low Current Sensor
Hi Everyone:
I am trying to build a megohmmeter and interface the voltage and current
readings into a stamp as a data logger and display. I was wondering if
anyone had any ideas for a circuit or components to put a high voltage (up
to 10000 VDC) with a low current signal (1-100 ua) into an ADC which then
goes into the stamp. This is a price sensitive project too. Older circuits
just used a needle movement ammeter that had gobs of isolation between the
moving parts and the chassis ground.
Any ideas would be appreciated. Cheers for now and thanks in advance.
Gerry Shand
res@i...
Gerry Shand
res@i...
