vac.pump
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1768541362
--- In basicstamps@y..., "max powell" <mpowell@t...> wrote:
> I am working on A project and need to buy A minture vaccum pump that
will run on low voltage dc. It will be mounted on A small robitic
platform with A small robotic arm and used to lift approx 8 oz if
anyone knows where I might look to find something like this I would
appreciate hearing from you.
> thanks max
> [noparse][[/noparse]Non-text portions of this message have been removed]
> thanks max
area it won't take much of a pump to do it. You could even use a cheap
battery-powered vacuum cleaner.
> I am working on A project and need to buy A minture vaccum pump that will
run on low voltage dc. It will be mounted on A small robitic platform with A
small robotic arm and used to lift approx 8 oz if anyone knows where I might
look to find something like this I would appreciate hearing from you.
low voltage dc. It will be mounted on A small robitic platform with A small
robotic arm and used to lift approx 8 oz if anyone knows where I might look to
thanks max
seal the suction cup to A flat alum. surface which is approx .5 lbs .
I dont belive I need A lot of vacuum but would like to find small pump 6-12
volts no more then 1 amp draw.
If anyone knows of any place where I might find such an item I would
THANKS
MAX
