Interfacing to High Voltage - suggestions?
I need to flash a strobe from a disposable camera. I need suggestions for
parts/circuits that can handle the typical flash voltage.
Can someone help me?
Brian Gracia
Brian Gracia
someplace like B&H photo:
http://www02.bhphotovideo.com/default.sph/FrameWork.class?FNC=ProductActivat
or__Aproductlist_html___38507___NOST___REG___CatID=1161___SID=F0B03460A30
If that link doesn't work search for:
Novatron Slave trigger
Mfr Catalog # 4030 * B&H Catalog # NOST
They are about $20.00 and will fire a remote strobe using the light from the
disposable flash.
From: Brian Gracia [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-yX0zefi_p_LXwClu_QgpL7qFuEjEIb9iP4lxG7iUWCGNjARHz7BQEKZrx7VAUy7XEPUB4s0ys6tadp1]bgracia@b...[/url
Sent: Monday, September 23, 2002 9:33 PM
Subject: [noparse][[/noparse]basicstamps] Interfacing to High Voltage - suggestions?
Brian Gracia
This e-mail message may contain legally privileged and/or confidential
information. If you are not the intended recipient(s), or the employee
or agent responsible for delivery of this message to the intended
recipient(s), you are hereby notified that any dissemination,
distribution or copying of this e-mail message is strictly prohibited.
If you have received this message in error, please immediately notify
the sender and delete this e-mail message from your computer.
ago. At any rate, I would use the whole module including the battery -- its
easier.
They have two sets of contacts to deal with. One set activates the circuit
that charges the high-voltage supply, and the other fires the trigger coil.
The charging part could use a regular relay, but the high-voltage part may
require something with a higher rating as its switching about 300-400 volts.
In any event the Stamp could trigger these relays, although I would try to
isolate the pins just in case the high voltage jumps from the contacts to
the coil of the relay.
