Infusion tips?
I am trying to develop an infusion set in which a motor will
control the gradual injection of a solution. I was wondering if
parallax sells a motor or similar device that works like a piston.
One in which the piston can be controlled to gradually extend, thus
causing the needle to inject the solution. Thanks for your replies
furnished us with a couple of "pump" assemblies for us to test the boards
with. They have a clip assembly that holds various sizes of syringe and
presses the plunger using a motor turning a leadscrew.
