problem with basic stamp 2 carrier board
Hi I've got code like so:
(i'm using a basic stamp 2 chip on a standard bs2 carrier board).
d var byte
serin 16, 16624, [noparse][[/noparse]dec d]
if d = 10 then getReading
if d = 20 then getSecondSensor
getFirstSensor:
i var byte
for i = 1 to 5
serout 16, 16624, [noparse][[/noparse]26] 'just a dummyvalue for test purposes
pause 1000
next
getSecondSensor:
j var byte
for j = 1 to 5
serout 16, 16624, [noparse][[/noparse]36] 'just a dummyvalue for test purposes
pause 1000
next
On the PC side I've got a VB application using (MSCOMM32.ocx) that
sends 10 out to the serial port, reads 5 numbers from the serial
port , sends 20 and tries to read 5 again.
However, I can only receive 26 5 times in my VB app. After sending
20, my app just freezes - it enters an infinte loop waiting for the 5
36's which never come.
Does anyone know what's wrong ? Is it beacuse of the limitation of
the stamp 2 carrier board as opposed to the board of education for
example - it can't support runtime serial communication through
serout as mentioned in the stamp manual under serin and serout.
Jim
d var byte
getFirstSensor:
i var byte
for i = 1 to 5
pause 1000
next
getSecondSensor:
j var byte
for j = 1 to 5
pause 1000
next
Jim
there appears to be a number of errors in what you have listed here.
Firstly, line 3 says to go to "getReading" I am assuming this line
should read "getFirstSensor".
I would suggest something like:
d var byte
i var byte
main:
if d = 10 then getFirstSensor
GOTO main
getFirstSensor:
for i = 1 to 5
pause 1000
next
GOTO main
getSecondSensor:
for i = 1 to 5
pause 1000
next
END
An IF-THEN statement works as a GOTO statement, this means that at
the end of "getFirstSensor" and "getSecondSensor" code sections there
needs to be a GOTO to tell the code where to go once it has finished
the 5 FOR-NEXT commands. With your code, I would expect it to finish
the 5 FOR-NEXT commands then drop into the "getSecondSensor" code and
then just stop as it has nowhere to go.
I have also removed the second "serin 16, 16624, [noparse][[/noparse]dec d]" statement
as it is not really necessary. By sending the it back to "main", the
code will receive the 20, and go to "getSecondSensor". Once it has
finished will END.
I have also removed the J variable as it is not required.
Hope this helps.
Cheers
Col
> d var byte
> getFirstSensor:
> i var byte
> for i = 1 to 5
purposes
> pause 1000
> next
> getSecondSensor:
> j var byte
> for j = 1 to 5
purposes
> pause 1000
> next
5
> Thanks,
> Jim
and at the end?
Also, I don't see any getReading label.
Right now, it looks like you have a single pass program. As soon as it
finishes the getFirstSensor loop, it falls through to the getSecondSensor
loop and then gets the last statement and ends.
I think you intended to get back to the top after finishing the
getFirstSensor and getSecondSensor loops.
You might want to change getFirstSensor and getSecondSensor to subroutines
with a return at the end of each, then just call them from the first part of
the program. You will also need a goto to complete the program.
From: jamesryfler [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IA-cHyPLYicOvJljEe5HTEasr6f-FFL5yy5fKsCEgoW5gChzJqD3UEcpdsTNUWTl_av5-zCJsVLXOTn9rSSIrSB4]jamesryfler@y...[/url
Sent: Sunday, September 22, 2002 5:54 AM
Subject: [noparse][[/noparse]basicstamps] problem with basic stamp 2 carrier board
d var byte
getFirstSensor:
i var byte
for i = 1 to 5
pause 1000
next
getSecondSensor:
j var byte
for j = 1 to 5
pause 1000
next
Jim
This e-mail message may contain legally privileged and/or confidential
information. If you are not the intended recipient(s), or the employee
or agent responsible for delivery of this message to the intended
recipient(s), you are hereby notified that any dissemination,
distribution or copying of this e-mail message is strictly prohibited.
If you have received this message in error, please immediately notify
the sender and delete this e-mail message from your computer.
