reading code
Sort of. See:
http://home.earthlink.net/~parkiss/recovery.txt
Steve
On 22 Sep 02 at 15:49, beamnut wrote:
> Is there some way to read the actual code stored in a BS2 chip,ie.
> to have it spit out the code exactly like it was programmed in?...
Steve
have it spit out the code exactly like it was programmed in? I tried
fooling around with the read command but didn't get the results I
wanted. All help appreciated.
There are two ways to read the code.
1. The memory map via ctrl - M shows the code exactly as it will be in the
EEPROM after down load.
2. If you have a basic stamp OEM kit, you could take the EEPROM out of it's
socket, and connect it up in a breadboard, and use another stamp to read the
EEPROM.
cheers,
Ben, Wellington, New Zealand.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Electronics R&D
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
> From: "beamnut" <lvollstaedt@h...>
> Reply-To: basicstamps@yahoogroups.com
> Date: Sun, 22 Sep 2002 15:49:59 -0000
> Subject: [noparse][[/noparse]basicstamps] reading code
> Is there some way to read the actual code stored in a BS2 chip,ie. to
> of the message will be ignored.
