Accurate data acquisition timing
Hi!
I'm trying to accurately time some data acquisition on the basic
stamp. I'm reading two axes of acceleration from the ADXL202
accelerometer and I'd like to accurately do this say, 8 times a
second - ie read it every 125ms. The problem is, if I execute the
code to read the accelerometer and then pause for 125ms (using PAUSE
125), the total time between readings is more than 125ms!
Does anyone have ideas for a way around this? Is there a way I can
accurately find out how many ms it takes to execute the accelerometer
reading code or can I read a time stamp from RAM or something??
Any comments appreciated!
Thanks!
Brad.
Thanks!
Brad.
after the loop from the time before and divide by 1000. If 1000 times is
not enough to get the resolution you want, do it 10,000 times.
Sent: Thursday, September 19, 2002 6:42 PM
Subject: [noparse][[/noparse]basicstamps] Accurate data acquisition timing
> Hi!
> Thanks!
> Brad.
of time, then do something for 125 ms, the total will be greater than 125
ms. I would make my pause shorter and shorter until I got the number of
reads per second you need.
> Why not stick it in a loop that executes say, 1000 times. Subtract the
time
>Thanks!
>Brad.
Hi Brad,
The most accurate way to do this is to use an external chip for the
timing. Maybe you will have a real time clock as part of your data
acquisition system? Lock into the 1 second tick of the real time
clock. Some real time clock chips like the DS1307 have a dedicated
one second period square wave output. There are other options using
an external chip, including an CD4060 chip with 32khz crystal, or
timed to the 60hz power line, or to WWVB, or an external timer chip
like the one from Peter Anderson or the PAK from Al Williams.
http://www.phanderson.com/clock.html
http://www.al-williams.com/awce/pak7.htm
It is possible to write Stamp programs that execute a fixed loop with
very accurate timing, if you don't want to go the route with an
external chip. Say your code takes 7 milliseconds to run the loop.
Then you use a PAUSE 118 instead of PAUSE 125. If you want to cut
the error even closer, you can pad the code with extra instructions
that burn up "exactly" the right amount of time. The PULSOUT command
is a good one for this because you can cut it down to microseconds.
However, it will not be as accurate as the external chip over the
long term. Be ready to tear out your hair when you go to change
anything!
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
TIMER0, and an external crystal oscillator without the overhead of a
PBASIC interpreter.
Just my .02,
Dennis
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k2INvLuCCGo9AfUycp1lZ1f4TCBraj5uIQFiYvtL90YK58zO-i-jgCCh36RYD7Sg5tVIv1GWrO1Z]daweasel@s...[/url
Sent: Thursday, September 19, 2002 8:01 PM
Subject: Re: [noparse][[/noparse]basicstamps] Accurate data acquisition timing
Why do you need to time it? If you do something for an undetermined
amount of time, then do something for 125 ms, the total will be greater
than 125 ms. I would make my pause shorter and shorter until I got the
number of reads per second you need.
> the
time
> is not enough to get the resolution you want, do it 10,000 times.
> > accelerometer reading code or can I read a time stamp from RAM or
> > something??
times a second -- 125 ms apart. However, he did not take into consideration
how long the read takes -- he was pausing for 125 ms and not 125 ms minus
the time it takes to do the read.
Sent: Thursday, September 19, 2002 10:12 PM
> >Hi!
> >Thanks!
> >Brad.
> Hi Brad,
> anything!
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> >Hi!
> >Thanks!
> >Brad.
> Hi Brad,
> anything!
> -- regards,
> Tracy Allen
> mailto:tracy@e...
still have most of my hair [noparse];)[/noparse] .
Dennis
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UZXFcrl4Jdncko8ZMjClZLiUOpBZoZC-fX7vqRQ2aVsZzwb4Lr1PCl1XxbzYADMxrCSmnhJ3Y1RKTvTqI4Y]daweasel@s...[/url
Sent: Thursday, September 19, 2002 8:34 PM
I think y'all missed his original problem -- he was trying to do a read
8 times a second -- 125 ms apart. However, he did not take into
consideration how long the read takes -- he was pausing for 125 ms and
not 125 ms minus the time it takes to do the read.
> >Hi!
> >Thanks!
> >Brad.
> Hi Brad,
> Then you use a PAUSE 118 instead of PAUSE 125. If you want to cut the
> error even closer, you can pad the code with extra instructions that
> burn up "exactly" the right amount of time. The PULSOUT command is a
> anything!
> -- regards,
> Tracy Allen
> mailto:tracy@e...
> and
churn in my head for a while... I'd like to avoid using an external
interupt, but I would also like it to be flexible, ie easy to change
the number of reads per second so the 'fiddle' approach may not be
the best...
Thanks again!
Brad
--- In basicstamps@y..., "Brad" <brad_j_schultz@y...> wrote:
> Hi!
PAUSE
accelerometer
> Thanks!
> Brad.
