Pulse Generator — Parallax Forums
Pulse Generator
edited 2004-02-01 19:43 in General Discussion
Hi! I'm 13 years old, and am currently working on a Basic Stamp 2
powered datalogger. The project needs an external input of a 10ms
pulse every 1000ms. What is the best and simplest oscillator that I
could build to provide this input? I was planning on using a 555
timer IC, but had trouble getting the proper values for the R1, R2,
and C1 in the standard 555 oscillator circuit. I was wondering if
someone could provide me with the correct resistor and capacitor
values or a different simple pulse generation circuit. Thanks!
Jacob Power
    edited 2002-09-19 15:57
    The 555 is still your best bet. First, to make figuring the values easier,
    download CS Microsystem's 555 calculator program -it's free and pretty neat.
    http://www.csmicrosystems.com/timerdesigner/index.html
    Next, since you may need a bunch of odd value resistors, get a few multi-
    turn pots and use those instead of fixed resistors. That way, you can 'dial'
    any value you want (within the range of the pot).
    Enjoy.
    Mark Hillier, VE6HVW
    President, HVW Technologies Inc.
    Canadian Distributors of Parallax Products and other Neat Stuff
    Tel: (403)-730-8603 Fax: (403)-730-8903
    See our NEW FPGA Experimenter Board
    http://www.hvwtech.com/intro-fpga.htm
    edited 2002-09-20 03:46
    Thanks to everyone for the quick and detailed responses. You provided me with
    excellent resources on oscillators. I have learned so much from this list.
    Thanks again!
    Jacob Power
    Wrom: PHSCRTNHGSWZ
    Sent: Thursday, September 19, 2002 7:52 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Pulse Generator
    Enjoy.
    from the same email address that you subscribed. Text in the Subject and Body
    Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ Get
    more from the Web. FREE MSN Explorer download : http://explorer.msn.com
    edited 2002-09-21 03:05
    >From: "jacobhpower" <jacobhpower@m...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] Pulse Generator
    >Date: Thu, 19 Sep 2002 02:30:19 -0000
    >Jacob Power
    >Body of the message will be ignored.
    Checkout this page:
    http://www.doctronics.co.uk/555.htm
    The 555 circuit will need an extra diode over normal circuits in order to
    generate frequencies with a duty cycle less than 50%. Duty cycle being the
    ratio between on and off time.
    For your particular application look at "More astables Extended duty cycle
    astable" That is the basic circuit that you need, but you can leave out the
    LED and the 680R resistor. Also the resistor and capacitor values shown will
    be different.
    Sorry my maths could be a bit shoddy right now, but this is what I get:
    High time = 0.69 X R1 X C
    Low time = 0.69 X R2 X C
    10.35 ms = 0.69 X 1K5 X 10uF
    1035 ms = 0.69 X 150K X 10uF
    R1 = 1K5
    R2 = 150K
    C = 10uF
    There are many other combinations of resistors and capacitors, maybe you can
    find values that give better timing. The values aren't likely to be perfect,
    using standard resistors and capacitors, even if you can find a
    theoretically perfect combination. Use 1% accurate components for better
    accuracy too.
    another good page to look at:
    http://home.cogeco.ca/~rpaisley4/LM555.html
    Paul
    _________________________________________________________________
    Chat with friends online, try MSN Messenger: http://messenger.msn.com
    edited 2004-02-01 19:10
    Hello,
    I am in need of a pulse generator. I built one using a 555 timer and
    a few parts. It drives an IR led to 40 khz. Does anyone have an idea
    on making one with a wide range? Do they have an ic that can be used
    to make a simple one?
    Curtis
    > Subject: [noparse][[/noparse]basicstamps] Pulse generator
    > Hello,
    > Thanks,
    > Curtis
    We have two versions. One for 38 to 40kHz, and one for 455kHz.
    http://www.rentron.com/remote_control/TX-IR.htm
    http://www.rentron.com/remote_control/TX-IRHS.htm
    Both can be used for simple IR carrier generation or IR serial communications.
    You can find schematics for several applications & details on the same pages.
    -Bruce
    tech@r...
